Question about Garden
The Slil hd3812 12" compound
  • Handie Andie
    Handie Andie Apr 06, 2011
    Is it type 1 or type 2?
    Clarify please. The blade hits the base rather than the slot for the blade to go through. Is that correct?
    Handie Andie
  • nolans_const Apr 07, 2011
    I don't see anywhere on it where it says type 1 or 2. The blade travels down through the red plastic plate and keeps on going until it strikes the metal under the red plastic base.
  • 710 Answers
I've been looking at the schematic for your saw. I can't find an owners manual either...
Many miter saws have an adjustment piece at the back of the saw where the upper part meets the base. That is the depth adjuster. You can set the saw to how far down you want it to go, for instance, if you wanted to do a lap cut rather than cutting all the way through. Some saws have this and some don't. Mine doesn't. I could not see what kind you had by looking at the schematic. Look around at the back and see if you can find anything.
Here's the number for Skil customer service: 1-877-754-5999
I hope this helps. If it does, I'd appreciate your vote. THanks,
Handie Andie
Posted on Apr 07, 2011
Brand new out of box but the blade touches the insert but also seems to touch the metal base at the dust funnel. Is there an adjustment somewhere? None obvious in manual.
Check the size of the blade as it is probably 1/2 too big for the saw
The correct size blade will have a diameter that will give sufficient clearance for that machine.
Feb 09, 2013 | Hitachi C12RSH 12" Sliding Compound Miter...
Recalibrating the angles
look on top of fence
see 4 holes
loosen 4 bolts (probably hex wrench) and fence will loosen also
framing square against loose fence and lowered blade (to calibrate square)
tighten fence,... square to blade
Jan 15, 2011 | Makita 10" Dual Slide Compound Miter Saw...
How to change a blade in a sears 10" compound miter saw
there should be a spindle lock on this tool, lower the blade guard without removing and hold the spindle lock and the screw is usually left hand thread.
Aug 31, 2010 | Craftsman Saws
My blade won't cut threw the intier stock. like somthing is stoping it from breaching the deck. There is no saw dust hindering it anywhere and it used to cut right threw.
turn the bolt counter clock wise on the arm, this will allow the blade to go lower...don't go too far or u will cut into the base and or fence.
Aug 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
How to turn the base for compound cuts
Is there not a piece metal at screw handle to push down on top,or pull up on bottom, then rotate?
Jan 13, 2010 | Saws
My blade gaurd will not automatically rotate out of the way when lowering the blade to make a cut , Ridgid 12' compound miter saw
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
Dec 02, 2009 | Ridgid Reconditioned 12 In. Compound Miter...
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
Feb 20, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Jun 20, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
