Question about Viking VGSC306-4B Gas Kitchen Range
Viking oven won't heat
Viking 6 burner gas oven
top burners and broiler work fine
oven lights, then flame decreases, flame dances, then goes out
oven does not reach desired temp.
  • 5 more comments
  • Anonymous Dec 29, 2008
    I have the exact same problem. Everything but the oven works consistently. Starter or light does flicker and then go out.
    oven doesn't heat. starter seams to be having a problem. gas light is inconsistent
  • ithaca9 Feb 10, 2009
    Mine heats up but takes about 1/2 hour to reach 350
  • Anonymous Mar 12, 2014
    My viking stove that has 6 burners and a griddle model VGIS4806GDSS that has 2 ovens has a problem with the two stove top burner igniters on the left side. On this model when you turn on any of the gas burners on the stove top all of the igniters spark normally but now the two on the left do not. The ovens and griddle seem to be working normally. What can be the problem and what is the procedure to change whatever part is defective?
  • Anonymous Mar 13, 2014
    When I set the oven temp, both the oven and the broiler units light up
  • Anonymous Mar 15, 2014
    When turned on oven gets to temp, and then temp goes down over time
  • Anonymous Mar 21, 2014
    during cooking the oven shuts off and then reignites constantly
Igniters need to be replaced
Posted on Aug 26, 2008
  • ian_baumel
    ian_baumel May 30, 2012
    BAD SOLUTION: if there is any flame at all the igniter is working. (After all, the igniter is only a heating element that ignites the gas). My guess, it's a valve/carburetor issue for the oven burners.
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
Viking oven burner not turning on properly
Sounds like your ceramic ignitors have worn out - apparently they are to be replaced every 3-5 years - at least I had a similar situation and this is how it was solved. I have two ignitors in the larger oven & 1in the smaller one. Easy to replace (60$/each) - two wire and one screw each. Issue is when they fail to heat up properly the gas valve doesn't open fully, or won't open at all.
Also I'd clean the burners when in there ... mine corroded a bit and required brass wire brushing. There is a small **** on the burner that had filled in (width of a piece of paper) which prevented the flame from moving to the opposite side of the burner - so essentially only one side of the burner lit.
Oct 14, 2009 | Viking VGIC485-6G Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
Viking oven only one burner will light
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Trouble with an Amana oven
check the door switch
check the termocouple
Jul 26, 2008 | Amana RanARG7302 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
1,137 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
