Question about Philips 34PW9818 34" TV
My philips hdtv 2003, went out of focus then the picture went dark over a day. I still have sound, but the screen is entirely black. why?
SOURCE: No picture on my Philips HDTV
possibly you have hit the vga button on the remote by accident. if you have, the red lite blinks and the picture goes off after a second or two. Hit the TV (not the power) button and be sure not to hit the vga accidentally.
Posted on Dec 01, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
  • 59 Answers
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: Philips 42PFL5432D-37 black screen
A local repair shop, recommended off ShopJimmy.com, repaired ours with the exact problem for less than $250 total. Inverters were bad. The parts were $50 each at Shop Jimmy so the shop dx'd the problem and repaired it for less than $250 total! Very happy.
Trick they showed us.... turn off lights in the room and shine a flashlight down the t.v. The picture can be seen which means it's not all the horrible problems you might think.
Posted on Dec 23, 2009
supertech6
  • 513 Answers
SOURCE: TV has sound..no picture
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Posted on Mar 21, 2010
I have a VA26L vizio tv, the screen went black I have power but no sound how do I fix it?
I would like to know if you would describe the picture or screen as a dark swirling cloud like one?
Mar 16, 2012 | Vizio VA26L 26 in. LCD HDTV
Screen is black after the initial white screen that displays "Philips" Sound there but black screen with no picture Menu does not show either Nothing but black
I believe a firmware update can fix this issue. However to be sure I would need your entire model number, including the numbers after the slash. You can put that entire model number into Philips support website, http://www.usa.philips.com/#/headernav/consumer/
Once you get to your TV's support page, you can look on the right hand side and find the firmware information. First I suggest you read the Read Me file to familiarize yourself with the update process and what issues it fixes. Then you can download the firmware to your computer so you can upload it to a USB drive to perform the update.
Hope that helps!
Jul 19, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Picture is not focused, color is off. When we
this sounds like the convergence ic's need to be replaced that should fix the problem
Jan 25, 2010 | Hitachi 57F500 57" Rear Projection...
Screen went black
Possible vertical output IC failure, which will cause the Picture tubes to shutdown but audio will still function. Try replaceing the vertical IC
Jul 15, 2009 | Philips 60PP9202 60" Rear Projection...
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
No picture,sounds and system operational
The vertical circuit may have its positive and negative supplies, but is the output waveform correct? I have seen many of those TDA vertical outputs open up and cause exactly what you are seeing. The + and - supplies are there but there is no output. Replacing the IC usually cures the problem.
Jun 21, 2007 | Philips 60PP9202 60" Rear Projection...
My picture went dark but the audio is ok on Philips model 51pw9303
your tv needs to be taken to tech i is having problem in the video and related circuit.or power supply.good luck
Apr 03, 2007 | Philips 51PW9303 51" Rear Projection...
Philips 34PW9818 34" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
