Question about Lexmark X4270 All-In-One InkJet Printer
When recieving a call on the regular line after you pick up the reciever the fax machine will continue to ring ehoward3@homesc.com
  • 384 Answers
Hi there, ehoward3.
You would need to revisit the configuration of your device, most especially the way it behaves whether its in "Automatic" or "Manual" fax reception mode. The latter is highly recommended if this AIO printer is sharing both fax and phone lines.
I have included the link which will thoroughly guide you through the process of setting up this AIO printer and how it should behave in accordance to your liking :
Lexmark Support
This guide has a very detailed step by step procedure, and is guaranteed for your ultimate guidance and for your future reference.
I hope this helps, Thanks for using Fixya.
Posted on Apr 07, 2011
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
You have to answer the hone to recieve the fax
Try unplugging the power cord for 10 seconds to reset the machine.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE.
Nov 25, 2008 | Brother MFC-8220 Fax
Fax and answring machine on same line
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Nov 19, 2008 | AT&T (1718B) Digital Answering Machine
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X4270 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
