Question about V, Inc. Vizio P50HD Plasma Television
50 in vizio only green light through back grill works
  • 10,515 Answers
You need to unplug the unit for few minutes, say 30 minutes and then turn it ON. If the problem persists, it would confirm an internal failure.There are a couple of different things that could cause this problem, the first is the power supply, and the second the main board. Also either sustain or scan driver board can cause this problem. To know exactly what board is the cause, you need to have electronic repair experience, and test equipment. If you have this let me know and I will assist you in the troubleshooting of this tv. Otherwise you will need a repairman at this point. You can expect a bill of anywhere between $400-$700, this is a good average, however it could be more or less.
I am sorry I don't have a quick fix or easy answer for you on this one, please let me know if you have the skills and tools and I will be happy to assist you. Also please let me know if there is anything else I can do for you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 06, 2011
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
How to fix my vizio
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 31, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a Vizio model P50HDTV20A. The problem is this. One day it would not turn on. I got the clicks then a green light. No picture no sound. So i let it sit with the green light on for awhile. Turned it...
Look for numerous bad capacitors on power supply or replace board. Also look for burn spot on square buffer ic's to left of cabinet with back off. Replace bd's as necessary.
Nov 09, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
50" vizio hdtv will not turn on and light in front not on
If TV is completely dead, no green/orange light, no any clicking sounds after you unplug it from the wall outlet and plug it back in - it is a problem with Power Board. Best case scenario - It's just a fuse that needed to be replaced. You have to remove back cover and locate fuses (1-4) on the board that power cord is attached to. You have to use multimeter to check it. If fuses are OK - next step is to replace whole power board. But before you do anything - make sure you got power out of the wall outlet and/or your power strip is in working condition.
Mar 10, 2010 | Vizio Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green Power Light
My TV does this if I do not switch the remote to TV instead of Cable. I am using HD DVR and have to switch back and forth from Cable to TV. Hope it works.
Dec 25, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Big POP no sound no picture
if you could see light orange or green is has power is probably teh Y and Z board
Aug 22, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
V, Inc. Vizio P50HD Plasma Television Logo
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
