Question about Stoves Ovens
Hi We have just purchased a 1986 model Evernew caravan with a Roden El Rancho 4 burner stove & oven but we did not get operating instructions. The stove is in pristine condition & all the gas jets, including the oven work but the oven will only work so long as I hold my finger on the "Fail Safe" button. Any ideas?????? Thanks in anticipation. Graham
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
MNTECH
  • 1543 Answers
SOURCE: Oven issue
Most likely you need to replace the WB2X9154 oven igniter. Remove the floor of the oven (two screws at the back wall) and lift back edge up first, then take out the rest of the way. One nut holds the flame spreader. This gets you to the burner assembly. The igniter is the round thing on the side, near the back. Do an "ask me" if you have more questions. If this helps, a "fix ya" rating would be appreciated. Thanks.
Posted on Sep 22, 2008
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
dniro592006
  • 121 Answers
SOURCE: I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Posted on Jun 11, 2009
  • 20 Answers
SOURCE: The pilot light on my caloric gas oven lights, but
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Posted on Nov 26, 2009
The stove burners work find, but the oven will not light
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 03, 2010 | GE JGRS14 Gas Single Oven
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
Changing stove from gas to lp do we need to open top of stove to do this?
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Sep 12, 2010 | Ovens
SELF-CLEAN
Here is a link to your manual.
Owners Manual
FYI - The '55' in your model number should be 'ss' for stainless steel.
May 21, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Oven not working!
we're having the same problem.lol
Apr 10, 2009 | Kenmore Ovens
Setting the clock on my Roden Europa oven
I have instuctions if you would like a copy Regards ian@bscprojects.com.au
Aug 30, 2008 | Ovens
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
295 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
