Question about Maytag Neptune MDE5500AY Electric Dryer
Hi! I would appreciate a little help solving my problem please. One day it was working, when I went back the next day it didn't work. Problem!! everything else on the dryer works except the heat. Im not getting any heat to dry the clothes.
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 07, 2011
Help 2003 hyundai
You had a starter replaced,paid for that,
even though nothing works,not even
the new starter?
Where did you go for that work?
AAA- didn't know they diagnose vehicles
& give advice,you been had by two parties
Jul 26, 2013 | Hyundai Motor 2003 Elantra
I have a Rockford fosgate P4004 with two 12'
I think you are right about the "fried" part. It would have to be opened up and repaired to be able to use it again
Oct 29, 2012 | Car Audio & Video
I have a 1990 ck 1500. a couple of weeks ago I was headed out the driveway, it was a rainy day, I hit my headlights and my radio went out.I immediatly turned off my lights and my clock was re-set at...
On the components, you might try a separate ground. See if that helps? Check the battery negative connections. I've seen this even on newer vehicle where instrument cluster or whatever would dim a little when you turn on headlamps. I think it's a ground issue? Just my opinion.
On any component that doesn't work, check voltage and ground, you could try a redundant ground.
Mar 13, 2017 | Cars & Trucks
Hi, couple of days ago i tried to change my password in yahoo mail, i don`t know what exactlly happened because i chose new pass and i put there and also i confirm it but i didn`t saved , after that i sign...
Please follow the below step for your problem.
Step 1: Open this link https://edit.yahoo.com/forgot
Step 2: Select I Forgot Password
Step 3: Click on Next
Step 4: Enter your email id-
Step 5: Enter a Code which you can see there
Step 6: Click on Next and do as per instruction
thanking you
davevipul197
Feb 01, 2011 | Yahoo Mail
Went to hospital parked car came out key fob not working opened key fob two of the sensors had come off.Managed to get it working to get home.went out to car with spare key fob but did not work opened key...
Im not sure there is any easy fix for this so I will just give a little advice.
Can you give me the make and model of the car? and is the alarm and immobilizer a standard factory one? Will do my best to help you once I know the make and model, and the year please.
Regards
Dan
Nov 07, 2010 | Vehicle Parts & Accessories
LG RUMOR went through washing machine!
you are lucky this time your phone is working tis time your phone is working and there is no way you can get your screen back but remember next timeif your phone goes through wash do not start it immediately let dry for atleast 3 days or else if you start it short circuit takes place for.now get a new phone for yourself
May 18, 2009 | LG RUMOR Cellular Phone
Sony ericsson 550i white screen problem
Try removing the battery anbd leave it out overnight. Then put back and try to turn on the next day. If this doesn't work then the phone needs to be flashed.
Dec 19, 2007 | Sony Ericsson W550i Cellular Phone
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
