Question about Whirlpool LSR5132PQ Top Load Washer
Pumps water out so fast it oveflows the drain even after the drain has been replaced by a plumber
    Scholar:
  • 125 Answers
Pull the drain hose up out of the drain if it has been crammed down inside. The hose should go maybe 4 inches down inside and be secured to something stationary so that it doesn't move. If the hose is shoved too far down inside, the water will not go down the drain and will instead come right back up and run all over your floor. Good luck.
Posted on Apr 06, 2011
How to Fix Hot Water Pipes Hammering/Banging?
Had a similar problem and found that the plumber who had replaced the recirculating pump had removed the plastic pipe hollders. These are spacers used to hol the pipes firmly as they pass through the wood studs. Even with only two spacers missing the hammering sound passed through the whole system. Once new spacers were installed the hammering sound stopped.
Jul 14, 2012 | Water Heaters
Water is not draining from bottom! , Sometimes it wont introduce water during the wash sequence....all valves are opened!
most likly you need to replace the impeller at the bottom, usually an easy fix on most dishwashers, two too four screws, remove the impeller (it has alot of fins) if these are worn or some are broken this is your problem. order from appl. parts store or sears. If the water isn't being pumped out the float valve won't allow new water in because it would oveflow.
Mar 21, 2010 | Dishwashers
The water from my pool is draining out even when the filter pump is off cant find the problem. is not from the backwash
Thank you for posting your question here on Fixya.com.
How fast is the water draining? Plumbing issues below the water line can be one source but so can warm water coupled with low ambient air temperatures which will speed up evaporation of the water. Is it possible you are just loosing more water than normal from cooler evening and/or nighttime temperatures? If not, you will need a plumber or pool service company to come out and pressure test your plumbing to isolate where it is leaking
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 15, 2010 | Jandy Aqualink Rs4 One Touch Control...
Waste drain does not take in water, spills out.
Replace the clogged drain pipe. You need a plumber. Washer is ok.
Jul 05, 2009 | Maytag Centennial MTW5807TQ
My washer drain pipe overflows when draining. i've tried smaller loads, cleaning drain pipe & vent, and raising the drain pipe. seems like the washer is draining the water too fast.
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Apr 30, 2009 | Washing Machines
Water won't drain thru
you need to clean the drain pipe, maybe draino or call a plumber to snake it out.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
G e Profile washer
hi thanksfor the question i would replace the water valve this will fix ya thanks the appliance doc
Jul 27, 2008 | GE Profile WPRE6100G Top Load Washer
Water overflows drain pipe when draining.
you don't you get a different plumber may only be a partial restriction in drain line and could be any where down the line water is pump out on some washer faster than a restricted drain can handle it and no there is no way to reduce rate water is being pump out..been there have the t-shirt
May 27, 2008 | GE WJSR1070A Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
