Question about Woods 60 Minute Decorator Wall Timer Switch
We have a fan 60 minute push button timer we purchased and installed with a 3-wire system. WE need to purchase another one but they all have 4 wires now. Where can we purchase a 3-wire one.
It sounds like you have mechanical push-button type timer.
I need more information to avoid guessing which timer is best for your situation.
I'm not sure what a 3-wire system is?
Add a comment
1) How many switches control same fan
2) What color wires inside box.
Is this
3) low-horsepower bathroom fan?
4) other fan, for example: higher horsepower attic fan, 3/4 horsepower industrial kitchen fan, or 1-horsepower whole house fan?
5) Is this your home or is fan for continual commercial use?
6) Is this a countdown timer that turns fan OFF automatically after 60 minutes?
7) Or what kind of timer are you looking for.
Open following link for list of home-use countdown timers and horsepower ratings of countdown timers.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Spring-wound timers do not require extra Neutral wire, and can control 1 HP whole-house fan.
The push-button timers each require Neutral wire to run electronics inside timer, and they range from 1/6 HP to 3/4 HP which will work for any bathroom fan.
If you cannot give required information for more free help, then request fixya interactive answer and pay fixya expert to ask same questions while expert supplies you with immediate information.
Posted on Apr 06, 2011
My Leviton 6260M is wired to a bath fan according to the diagram provided: Green wire connected to ground, White neutrals connected together, Black wire connected to 'line' feed wire, Blue wire connected...
Countdown timers are made to work with bath fans.
Leviton countdown timers are stout product with 1HP rating.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6200
It sounds like timer is bad.
Wiring sounds good. Make sure you don't have Load and Line wires reversed. Try reversing Load-Line wires and see what happens.
Another thing that affects electronic timers is line noise/interference. If replacement timer does same thing, then noise is suspect. Try timer on another circuit without fan. Try another brand timer. Update to newer LTB60 Leviton timer. Use cheap circuit tester from home center to check outlet on same circuit.
Apr 04, 2011 | Leviton 6260M-T Timer Switch 10-20-30-60...
Despite the fans working on a plain Jane single pole switches, I can't get these 6515M switches to work for my 1.3 ceiling fans. The fan hums and all I get on the timers are red LEDs. These timers...
1) Leviton 6515 is incandescent only:
http://www.amazon.com/Leviton-6515M-I-2-5-10-15-Electronic-Incandescent/dp/B0007NOZDI
2) Below is list of countdown timers with horsepower rating so they work for fans:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
3) Following timers are NOT rated for fans:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors.
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Feb 26, 2011 | Leviton 6515M-W Timer Switch, 2-5-10-15...
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Dec 22, 2010 | Woods Ind 59008 Digital Timer
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Nov 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I purchased the Legrand RT1 Time Switch to run a bathroom fan. It is installed and I see indicator lights. Every time I turn the fan on, it runs for a second and stops (hearing clicking in the switch);...
You connected red and white wires together.
No problem, nothing burned out, and it's simple to fix. Steps below.
RT1 is electronic countdown timer, and electronic timer clock inside needs separate circuit, just like your alarm clock needs to be plugged in. >> that's why timer has white wire. White wire completes circuit to timer clock.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Heres what to do
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push countdown button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 27, 2010 | Pass & Seymour / Legrand RT1-W 10-20-30-60...
I purchased the 6161T Preset Electronic Timer Switch and I am struggling to hook it up. I am trying to install it in a Hallway that has two switches for the same light. I have a Red, Black and White wire...
The timer you have purchased will not work for 3-way switching.
We know this because the wires are color-coded.
And you have 2 black wires.
Good job providing that information so I can see what you have.
Both your timer wires are black, and that tells the electrician that the timer is made for single-pole only.
That being said, there are timers that have the same color wires as your 3-way switch, but the timer has to say it works for 3-way circuit.
Usually the instruction sheet or package will say, 'for single-pole.'
Or it will say, 'for single-pole and 3-way.'
1) Aube makes programmable 7-day timers for a 3-way installation.
But this timer is not for countdown.
2) I am searching the web for a 3-way countdown timers, and Levition offers one, but they require you to replace both 3-way switches and then install a 'master-and-remote' combo.
This means each timer is a different model number.
If you want help sorting out that purchase, add a comment and I will research the Levition site.
3) Smarthome sells a countdown timer for 3-way circuits.
It appears to be exactly the product you are wanting.
The product has 95 ratings with 4-1/2 stars
http://www.smarthome.com/2476ST/SwitchLinc-Timer-INSTEON-Countdown-Wall-Switch-Timer-Non-Dimming-White/p.aspx
The product manual is right there on the Smarthome page.
They provide an installation video.
Smarthome is very customer friendly.
I specialize in timers and electrical devices, but I do not know the product shown above.
However I can help you install it.
Add a comment and I will help further.
Nov 03, 2010 | Leviton 1000W / 20A 1HP-120V - 6230M-I -...
I paid $20 last night to talk to someone. He told me how to hook up the Lux DMH110 but when i hooked it up this morning the heater came on when i put it on COOL and the fan just come on when i put it on...
If you have this type of system your thermostat will not work;
  • Multi-Stage Heat Pumps
  • 3 Wire Hydronic Systems
  • Line Voltage Systems (120/240 VAC)
  • This thermostat is only for this type of HVAC systems;
  • Most 24V Heating and A/C Systems
  • 1 Stage Heat/1 Stage Cool: Gas, Oil, Electric, or Single Stage Heat Pump Systems
  • 2 Wire Heat Only Hydronic Systems (Hot Water Baseboard & Radiator)
  • Millivolt Systems (Wall Heaters / Furnaces & Gas Fireplaces)
    1. Never connect a low voltage thermostat to line voltage.
    Two wires control a heat only system.
    1. Connect one wire to W and the other to RH.
    Two wires control a cool only system.
    1. Connect one wire to RC and the other to Y.
    Three wires for forced air heat only system, where the previous thermostat
    did not have a clock or timer.
    1. The previous RH or RC wire is the 24-volt transformer wire. Connect it to RH. Leave jumper connecting RH to RC. Connect the forced air heat system to W, and the fan wire to G.
    Three wires for a heat only, forced
    water system that did NOT have a
    clock or timer.
    1. This system employ 3 wire zone valves. Currently no Lux controls are compatible with this system.
    Three wires control a heat only, forced water system that DID have a clock or timer.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W.
    Four wires control a heat only system,
    and two of the wires operate clock or timer. The other two wires operate the heater.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W. The jumper connecting RH to RC may remain or be removed.
    Two wires control heating AND cooling.
    1. Currently no Lux controls are compatible with this system.
    Three wires control heating and cooling. One wire operates heat, one operates cooling and the third provides 24 VAC.
    1. Connect the 24-volt power wire to RH. Install a jumper connecting RH to RC. This jumper is usually pre-wired. connect the heat wire to W, and the cooling wire to Y.
    Three wires control a cooling only system. One wire operates the compressor, one operates the fan and the third provides
    24 VAC.
    1. Connect the 24-volt power wire to RC. Connect the cooling wire to Y and the fan wire to G.
    Four wires control a heating and cooling, electric, gas or oil, forced air system that
    is NOT a heat pump.
    1. Connect the 24 VAC transformer wire to RH or RC. Install a jumper connecting RH to RC This jumper is often prewired. Connect the heat wire to W, the cooling wire to Y. and the fan wire to G.
    Four wires control a Single Stage Heat Pump. They were labeled: G, Y, R or
    RH or RC, With either B or was used.
    1. Do not connect wires to both B and O. Connect the reversing valve wire to B or O, just as the previous thermostat. Install a jumper wire from RH to RC. Connect 24 VAC wire to RH too. Install a second jumper wire from W to Y. Connect compressor wire to Y and the fan wire to G.
    More than 4 wires are connected to the
    old thermostat
    Jun 27, 2010 | Heating & Cooling
    Is the GFCI frying my intermatic timer?
    First off is the black wire feeding the gfci going to the brass colored screw? If so make sure the black wire coming out of the timer is attached to the brass screw on the gfci and the white colored wire is attached to the silver screw. If these are all connected properly it is possible that the fan isn't wired properly.
    Aug 10, 2009 | Intermatic FF60MC Energy Controls -...
    Woods 60 Minute Decorator Wall Timer Switch Logo
    478 people viewed this question
    Top Woods Hardware & Accessories Experts
    Gene Haynes
    Colin Stickland
    Colin Stickland
    Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
