Panel powers up.... When you hit spin only... It sounds like a relay or circuit breaker clicks on back of the control panel...... Can turn motor by hand....cannot turn center shaft. When the control head clicks.... nothing is felt at the motor... almost like power is not being sent down to it
  • dartcar2 Apr 06, 2011
    Sorry about the info problem
    Jenn-air/Maytag JW 3000 top load machine
    Machine is 14 yrs old
    Drive motor replaced 3-4 yrs ago / washing rugs and smoked it
    Electric control Touch panel replaced 6-8 years ago / Don't remember why
    Hav'nt checked for amp draw yet.... Need to optain a wiring diagram to make life easier
    going to ck w/local appliance parts store for manual first
  • Washing Mach... Master
  • 2,605 Answers
Hello, Welcome to FixYa. I can't seem to access any previous post (if any?) dialog that may have taken place but I'd like to help if you can fill me in on whats taken place to this point. Also if you could provide the make and model number that will help avoid any generalizing with you machine. I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Posted on Apr 06, 2011
  • Mark MacDonald
    Mark MacDonald Apr 06, 2011
    Hello again,
    Thanks for your reply.
    The place I'd start is to confirm the belt is ok, you should be able to inspect it visually by tilting the washer back and also the motor is A) getting 120vac and B) drawing amps.
    It is necessary to have a multi-meter and preferably a "clamp-on ammeter". These are test's that require the unit to be plugged in (aside from inspecting the belt) so please use caution...if you are not comfortable doing this please call a pro.
    Let me know what you find and I'll continue to help in any manner I can. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    OK sounds good. Though there should be a wiring diagram inside the console behind the control panel...unless it has been misplaced over the years.
    I'll watch for your reply post as to your progress and help in whatever manner you need going forward. Good luck.
    Regards,
    Macmarkus :)
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
1998 vw passat my 4 windows and sunroof quit working, i have tried fuses and disconnecting power frm pos of battery for 5 min stiill no help . everyone says relay problem but no one can tell me where the...
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door.
Drivers door window gets used the most so it could be the motor, window switch, relay or fuse.
Could also be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released.
The motor and the relay are the most likely to cause this problem. Try swapping the relay with a working window relay. If it still doesn't work, remove the door panel and remove the window motor.
Turn the motor shaft in both directions by hand several turns. Then plug the motor in and see if the switch will now run the motor. Sometimes that's all it takes to get it working again. I have had to do this with brand new motors. If voltage is not present at the motor connector, either a bad switch or a broken wire exists. Make sure to check for voltage coming to that windows switch. Actually, GM use's a circuit breaker type relay for each window and one fuse for all the circuit breakers.
Try this....
Open the door, turn the key to the ON position without starting the engine and everything that makes noise is off. Lean down placing your ears close to the bottom center of the door or at the speaker grill. Press the window switch UP and DOWN. Listen for the window motor. If heard the drive is damaged. If not heard, turn key off and locate and replace the relay with one of the other window relays. Check window again. If it works now, get a new relay. More often than not, removing the motor and turning it by hand will get it working good as new. I have had to do that with Brand New motors! So try it.
If all has failed, with the door panel still off, check for voltage at the motor connector when pushing the window switch. No voltage means its the switch, especially if its a auto down or up switch.
Check the master window control panel on the driver's door. There is probably a lockout switch. It may have a window outline on one end and the same outline with an "X" over it on the other. Press the outline without the "X" and all your windows should work again. As silly as that sounds, a lot of people hit that switch without knowing it. Also, if that switch(lockout) is faulty, none of the windows will work. That happens A LOT!!
Aug 28, 2011 | 1998 Volkswagen Passat
When starting a cycle, tub will fill properly, then when it is time for the wash cycle to begin, nothing happens. you can only hear a relay or other type switch click one time. after the one click, the...
The question is why the main motor is not running. Either there is an open contact in the timer, or the motor has a blown thermal protector or tripped internal breaker.
Troubleshooting starts at the timer. Most washing machines have a wiring diagram on a sheet of paper either folded up and stored inside the control panel or pasted on the back panel of the machine. Find the wires going from the timer to the motor. The motor has two windings, RUN and START. The RUN winding has one connection to neutral (WHT or WHT/BLK, meaning white or white with a black stripe) and the other to the timer. The START winding has both connections going to the timer. The timer connects it power one way for agitate and the other way for spin. (The direction of current through the START winding determines whether the motor will turn clockwise or counterclockwise.)
If you are comfortable working in a live 120 VAC circuit with a voltmeter, use the wire colors in the diagram to identify the motor terminals on the timer, set the timer to the agitate position (i. e., right after the machine is done filling and you hear the click), then check for voltage on the RUN and the START winding terminals. For the START winding, measure between the terminals going to the START.
If you don't want to probe a live circuit, you can use an ohmmeter to test for continuity between the hot terminal of the power cord and the motor terminals on the timer. Repeat for the neutral terminal. A failure at this point indicates either a timer problem or (unlikely since the timer runs) a bad contact on the water level switch.
If you get voltage to the motor on both windings, or you have continuity through the timer for both windings, then, with the machine unplugged, test for continuity through each motor winding at the timer. An open indicates a problem with the motor. Note: most machines use a capacitor in series with the START winding. In that case, measure continuity between the capacitor terminal going to the motor and the timer terminal going directly to the motor.
Apr 17, 2011 | Washing Machines
NO REAR WINDOW DEFROST
First thing to do is test these fuses with a tester light. Check the A/C cruise control fuse 10 amp (left side of dash in panel), heated mirror fuse 10 amp (right side of dash in panel), this is also where you will find the circuit breaker and relay for the rear defroster. Test the breaker for power in and out. Feel the relay to see if it clicks when you turn on the rear defrost
Aug 18, 2010 | 2003 Chevrolet Impala
Where is the fuse for power windows?
I know on a 83 its located by the glove compartment ,, try looking there
Aug 02, 2010 | 1990 Chrysler New Yorker
My sunroof is not able to be closed. It is in the pop up position. Is there a manual way to close it? eg no use of electricity?
there is no manual method. It sounds like a limit switch is not working. Can you hear the motor try to operate? If you push up on the back of the glass a little bit while hitting the switch, what happens.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
The sliding roof panel system consists of the following components:
  • RH circuit breaker
  • Timer module
  • Power window relay
  • Roof sliding panel switch (15B691)
  • Roof glass panel (50054)
  • Sliding roof panel motor (15790)
  • Halo moulding
  • Roof sliding panel headlining (519A02)
  • Roof sliding panel slide links (502M78)
  • Roof sliding panel housing (502C22)
  • Roof air deflector (500A26)
  • Center green diode strip
When the roof sliding panel switch is activated, a gear on the sliding roof panel motor drives a spline on the roof sliding panel housing. Within the roof sliding panel housing, the spline is connected to two sliding roof panel cables which cause the roof sliding panel slide links to slide and the roof glass panel to open or to close. The sliding roof panel cables and the spline are part of the roof sliding panel housing. Neither the sliding roof panel motor nor the roof sliding panel housing can be disassembled. If a malfunction is detected with either of these assemblies, the assembly must be replaced.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged sliding roof panel
  • Sliding roof panel height adjustment
  • Sliding roof panel fore and aft adjustment
  • Blown fuse(s):
    • 30A PWR WDW
  • Damaged circuit breaker #1
  • Damaged wiring harness
  • Loose or corroded connections
  • Sliding Roof Panel Does Not Open or Close
  • Fuses.
  • Circuit breaker #2.
  • Power window relay.
  • Sliding roof panel motor.
  • Roof sliding panel switch.
  • Circuit.
  • GO to Pinpoint Test E1 .
  • Sliding Roof Panel Will Not Stop in Vent Position
Switch Removal
  1. Disconnect the battery ground cable (14301).
  1. Gently pry the overhead console from the headliner.
  1. Disconnect the sliding roof panel electrical connector from the overhead console.
  1. Disconnect the rear quarter window switch electrical connector from the overhead console, if equipped.
  1. Disconnect the map lamp electrical connector from the overhead console.
  1. Remove the overhead console.
  1. Remove the two roof sliding panel switch screws and the roof sliding panel switch (15B691).
Motor Removal
  1. Place the roof glass panel (50054) in the closed position.
  1. Remove the roof headlining (51916). Refer to Section 01-05 for the removal procedure.
  1. Remove the two sliding roof panel relays from their brackets.
  1. Disconnect the two sliding roof panel motor electrical connectors.
  1. Remove the two sliding roof panel motor screws and the sliding roof panel motor (15790
Jan 11, 2010 | 1997 Mercury Villager
FUZE BOX DIAGRAM FOR 1990 MERCURY TOPAZ
Replacement
  1. Access the fuse panel from the left of the steering column.
  2. Locate the blown fuse and pull out. DO NOT TWIST.
  3. Take note of the ampre number written on the top of the fuse. To install:
  4. Push a new fuse of the same ampre into the receptacle, making sure the contact is being made on both sides of the fuse.
LOCATIONS Headlights and Highbeam Indicator
  • One 18 amp circuit breaker (22 amp in 1987 vehicles) incorporated in the lighting switch.
Front and Rear Marker, Side Parking, Rear and License Lamps
  • One 15 amp circuit breaker incorporated in the lighting switch.
Windshield Wiper
  • One 4 1⁄2 amp circuit breaker located in the windshield wiper switch.
Power Windows
  • Two 20 amp circuit breakers located in the starter relay and the fuse block.
Power Seats and Power Door Locks
  • One 20 amp circuit breaker located in the fuse block.
Hazard Flasher REMOVAL & INSTALLATION NOTE: The hazard warning flasher is located on the rear side of the fuse panel.
  1. Locate the hazard flasher in the fuse panel.
  2. Pull the flasher out. DO NOT TWIST. To install:
  3. Push new flasher into place making sure a good contact is made with both terminals.
  4. Test flasher to make sure they function properly.
Various Relays LOCATION Cooling Fan Controller
  • Located behind the left side of the instrument panel.
Cooling Fan Controller Module
  • Located behind the right side of the instrument panel.
Cooling Fan Relay
  • Located in the air conditioning cooling fan control module.
Electronic Control Assembly
  • Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
  • Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
  • Located behind the glove box.
Horn Relay
  • Located in the fuse block.
Fig. 1: Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal
This is the best info I could find....I hope this helps ya!
Jul 23, 2009 | Mercury Topaz Cars & Trucks
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
Akai X-360 Reel to Reel won't play
The Akai X-360 will not function if the remote control or the remote dummy plug is not plugged in to the back of the machine. The remote Dummy plug has two jumpers for completing the circuit paths for the relays so that the front panel buttons will function.
Apr 17, 2009 | Audio Players & Recorders
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
