Question about Lincoln Electric Century Portable Plasma Cutter - 25 Amp # 82021
NO PILOT ARC, all 5 LED's light up on circuit board and air blows out of the tip when the torch button is pressed. Air is set at 65PSI all contacts have been cleaned,cables checked, and consumables have been replaced
Uniplas 30 power light flashing
See if the torch electrodes MIGHT be stuck... welded together. They have to arc and then separate or unit will shut down.
Jun 15, 2012 | Welding Tools
For 10 years, I lit my Williams Direct Vent Wall Furnace by using the red spark ignition button. For the first time, It would not work so I tried to light the pilot light by removing the wingnut to the...
Put a coat over the vent this will stop the it blowing the match out . don't forget to take it off . Pilot my need cleaning or thermocouple replacing .
Mar 28, 2017 | Heating & Cooling
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
KTM 625 SXC Bike wont start.
Classic dirty carb problem. You will need to pull the carb off. Soak it in a gallon carb cleanerwstariner($15)-available most auto parts stores. Get a set of torch tip cleaners($5) at Lowes/HD. A can or two of carb cleaner spray. And a good source of compressed air with rubber tip air nozzle. Best to let it set for atleast 2 days in the cleaner. Bottom out any adjustable screws and right down # of turns for easy assembly. Pay attention to all the little air/fuel circuits theres even 1 in the float bowl that does a hard 180 thats tough to get clear. Thats where those torch tip cleaners will come in handy. Blow every circuit with air---watch out for any orings stuck in the carb they wiil fly across the room never to be found again. You usually can reuse the all gaskets so no parts needed.
Apr 01, 2010 | 2005 KTM 625 SXC
Air is coming out of the hole where you light the pilot and blows out the fire.so i cant light the pilot. it was working fine until this morning
You have a major down draft. You will need a torch to overcome the air coming out of the pilot hole. Or if the heater has another door that can be opened to allow the air to escape there.
Jan 08, 2010 | Heating & Cooling
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
I NEED TO AIR ARC CAN THIS MACHINE DO THIS AND HOW
hook up to the stick position on the machine - to work + to the stinger hook stinger to the air arc hook up air to the air arc turn welder up to top {350}turn air on at the push button on the air arc & get busy
Apr 09, 2009 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
The heater in my central heating is not getting turn on but the fresh air and cooling is getting turn on
Check the pilot light.Older standing pilot systems use thermocouples to verify the pilot is burning before the gas valve opens.If the pilot wont stay lit replace the thermocouple.
Newer systems light the pilot.On a call for heat the igniter lights the pilot. When the heat is verified the gas valve opens . Some systems use an circuit board with flashing led lights to help troubleshooting.
Jan 11, 2009 | Heating & Cooling
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Lincoln Electric  Century Portable Plasma Cutter - 25 Amp # 82021 Logo
83 people viewed this question
Top Lincoln Electric Welding Tools Experts
Troy
Troy
Level 1 Expert
AZBen
AZBen
ka4iup
ka4iup
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
