Question about Frigidaire Ovens
Don't know how to set clock on frigidaire range model # RG94BF*0 please help
There are 3 knobs below time display and one to the right.
Push the right 2 buttons at the same time while turning the right knob to set time..
Posted on Nov 03, 2015
2 Suggested Answers
SOURCE: replace clock on range
replace clock on range frigidaire 367cesd
Posted on Jun 26, 2009
Setting the clock it is a frigidaire elite stove
Hello Susan, thank you for your post!
I understand that you need help setting the clock on your Frigidaire range. Could you provide me with your model number please? You should be able to locate the serial tag (which lists the model number) on the frame behind the bottom drawer. With this information I can better assist you. -Matt
Mar 13, 2015 | Frigidaire Ovens
Frigidaire oven and broiler stopped working but clock andtop burners work
Hello Friend, this is Z. I am happy to assist you!
I see that both the clock and burners of your Frigidaire range are working but your oven does not bake or broil. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you!
Sep 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Turned on oven to 325 degrees it kept heating till very hot and now oven will not turn off
I understand that your Frigidaire electric oven will not shut off. I also see that it gets very hot, way past the set temperature of 325 degrees. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. If further troubleshooting is needed, please leave me the model number of your range. Typically this number can be found on the back of the door or possibly in the bottom drawer. Hope this is helpful.
-Best Regards-
WP
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Oven does not work, but the range top will?
Hi, Are both the bake and broil elements out?You will need to test the bake element first. Sometimes the element will have bubbles in it where it went bad. UNPLUG the range and remove the 2 screws holding the element in. With an OHM meter, check the element to see if it has continuity. If the test shows an open circuit, replace the element. If the test shows a closed circuit, there could be a bad wire connection, or a problem with the thermostat/clock assembly.
The clock assembly cost is around $100.00.
It might be a good idea to call a repaiarman out to be sure.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 09, 2009 | Ovens
Replace clock on range
there is screw on back of range. remove screw and pull of back cover. that will expose clock. make sure you unplug unit first. don't forget where wires/plugs go
Jun 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do you set the clock
You didn't mention a model number. If you have a touchpad, press clock turn temperature control up or down. When the correct time is set, press clock again.
Apr 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire free standing range
Please post the model number for he stove in question. Its harder to advise without it.
regards
Nov 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
119 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
