Question about Westinghouse 32" Flat Panel LCD HDTV
Year old Westinghouse sk-32h540s TV can be turned on but then does not respond to any side controls or remote controls at all. No sound, no picture, no response. I can't even turn it off without unplugging the power supply. The blue LED in front lights up and the backlight lights up as well. Once in awhile it works after I have left it unplugged for hours. Thanks
  • 11,361 Answers
It really sounds like you are having the problem with the main board which get the control signals from the remote and side buttons and it is not processing those signals right now. You should inspect the main board voltages which you will need service manual to do that.
Here are the replacement boards
http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+sk-32h540s+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 06, 2011
Westinghouse sk32H540S picture come on then off what's wrong sound good
It's a bad capacitor on the power supply/backlight inverter board. Replace the board and you won't have any more problems.
May 23, 2014 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse 32H540S Remote Program
You have this backwards. The codes are in the remote. If you are using a Westinghouse remote, there should be no programming necessary. If you are using a universal remote, you can use the code search function to find a code that will control your TV.
Dec 03, 2013 | Westinghouse SK-32H540S 32 in. LCD TV
My Westinghouse SK-32H540S TV comes on for about 5-10 seconds, then the picture goes off. The sound continues.
You need to replaced your Inverter Board, If you can do the job, get the Board Part number and order it from Westinghouse. If not call a Professional TV Technician. At least you have an idea what's the trouble with your set. Hope this Tip will help you.Thanks
Aug 12, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse LCD TV SK-32H540S, 1 year old. When I turn it on, the screen works for about 5 seconds, then goes dark; power is on - sound still works but no picture
1 swollen Capacitors / Replace
2 blown Diodes on inverter board / on some # 508 or 908
3 bad transistors in inverter bad will appear overheated powdery coat
4 replace inverter if you cannot locate problem on it
there is a safety built into the high power back light supply and that is if too much current is drawn or light is shorted it will not burn up
or hazard high volt shock to user.
capacitors and diodes driven with power transistors
look for darkened spots on the board to identify hot transistors
puffy tops and leaky bottoms of capacitors
when you turn it on does the bottom or top of the screen show image a Milli second before the other it should be evenly the lag
is the one requiring more amperage
Aug 07, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Apr 06, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
TV Turns on picture comes on for 30 seconds then picture goes off and sound stays on. Even after leaving tv on the sound stays but the picture does not come back on. Its a westinghouse SK-32H540S
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Feb 26, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Picture comes on for 15 seconds then turns off, sound still works
One of the transformers on the inverter section of the power supply board has failed. Part can be found on line ($29.99). Also check for faulty and poor solder connections.
Jan 24, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse 32" Flat Panel LCD HDTV Logo
345 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
