Question about Northstar Ns100ss Dual Station Kit
My handset wire was cut can i replace the handset only and who carrys it.
No incoming voice heard during telephone conversation!
I am checking possible solutions for you, meanwhile can you please test in speakerphone mode. So we can conclude whether its Function or Hardware related issue.
Thank you in advance
Feb 06, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
How can I get new batteries
Normally in the BT range the batteries are rechargable, hence the base charger, so do not use ordinary batteries. If the phones are not charging, go to boots or tesco and buy AAA rechargeables 2 per handset. Once replaced allow at least 6 hours charge before use. After that just carry on as normal.
Jul 23, 2014 | BT Freestyle 750 Digital Cordless Handsets
Receiving party complains of low audio from this phone
There is a small electric condenser microphone in the handset where you talk, chances are the mic is defective and must be replaced. Radio Shack use to carry two or three different types, not sure if they are available. The handset will need to be dismantled and some solder work required.
Jan 08, 2011 | GE 29385GE1 Corded Phone
My cortelco able-phone keeps cutting in and out while talking its hard to carry on a conversation
try replacing handset cord, these cords are generally interchangeable from any other phone
Dec 07, 2010 | Cortelco Colleague 2211 1Line Corded Phone
Where do i get a new battery
You can order the battery direct from Uniden on their online store at:
http://www.unidendirect.com/
It is also possible that Radio Shack may carry a replacement but I highly suggest if you check there you carry the phone handset or at least the battery with you.
Apr 27, 2010 | Uniden Corded Phone with 5.8GHz Cordless...
Model 25922 5.8 Gh cordless
if they were hard wired yes , but since they are assigned frequencies and registered to base . no .
Dec 31, 2008 | GE 25942GE2 Cordless Phone System
Handsets bypassed; need to restore (follow-up)
These phones have a horrible problem with the hook switch. If you can only get the phone to work in speakerphone mode, most likely the hook switch is shot. If nothing happens when you lift the handset a bad hookswitch is likely. If the hook switch works but the talk path in the handset does not work, there may be a cut jumper wire. The wire is cut when a headset adapter is installed and if that adapter was later removed it will effect the talk path for the handset. If you take the back of the phone off you can see the jumper (visible from the back of the circuit board through a notch next to the speaker) If you can use a soldering iron, a cut jumper can be repaired easily by bending the wire back so there is only a small gap and soldering it. -Ben
Feb 23, 2007 | Toshiba DKT-2010 Corded Phone
I found some old notes of mine you could try, but they're involved: 1. [Spkr],#,603,500,[Speed Dial],[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,656,9,phone extension,[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,657,#,phone extension,[Redial],[Spkr],pick up hand set, hang up. Were you able to find a free manual online? Pat
Feb 20, 2007 | Toshiba DKT-2010 Corded Phone
Northstar Ns100ss Dual Station Kit Logo
98 people viewed this question
Top Northstar Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Northstar Boating Expert? Answer questions, earn points and help others
