I need a electrical schematic for a Coleman Evcon electric furnace Model: EB17A Serial: 940582998 I'm a HVAC contractor of 26 years The schematic inside of this furnace is missing, this owners husband is on active duty in Iraq. My Email-- Kennair07@yahoo.com
4 Suggested Answers
morefords
SOURCE: have a coleman evcon furnace
Your centrifical swith is stuck open on your blend motor. I found that removing the blend motor housing and spinning the stuck motor (from setting over the summer) will get you out of a bind ,.but you may end up needing this centrifical switch (locatedon the bottom of the blend/fresh air intake) motor replaced.
Posted on Nov 07, 2008
  • 233 Answers
SOURCE: need a downloadable pdf electrical
http://www.colemanac.com/PDFFiles/036-31114-001-C-0109.pdf
Posted on Jul 15, 2009
tbreeze47
  • 3083 Answers
SOURCE: The furnace model #4334-749----/serial #
The following blog is an excellent troubleshooting guide for RV units, and should help you solve this problem:
http://rvbasics.com/techtips/rv-furnace-problems.html
The propane valve is the first thing to suspect.
Good luck, and hope this helps.
Posted on Nov 27, 2010
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman furnace bgm10016ax 4 blinks
Usually on a metal panel you have to remove to access the board there is an electrical diagram. On the side of that is usually a description of what specific blinking codes mean.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman EVCON GAS FURNACE ugab075bua
Would need to have a serial number to determine.
Oct 13, 2013 | Coleman 7990-319p Evcon Gas Furnace...
How old is my Coleman Evcon Furnace, Modle Number: DGAT056BDE? I can't seem to find a Manufacturing date sticker. It was claimed to only be a year old, now living here a year it would now be 2 years old. ...
The Serial Number would really help in defining how old your Coleman furnace is. The model you have is used predominantly in manufactured housing. To find the Serial Number, you will need to remove the upper shroud of the furnace. There should be a sticker or plate on the back of that shroud of just inside the housing of the furnace, that will give you the Model # & Serial #. Armed with that, you can do a little detective work, as to it's age.
Mar 03, 2011 | Coleman Heating & Cooling
I have a coleman evcon furnace that wont work. The electrical box green light is not on at all so it cannot pinpoint what the error is. Any thoughts?
Hi, I would just make sure you have power to the furnace. Check breakers or look for the power switch on the electrical box. Also, some mobile homes have a wall switch that cuts power to the furnace.
Jan 16, 2010 | Coleman Propane Forced Air Heater...
My mother had a new Evcon Furnance installed through energy assistance programs. She has a manufactured home. Today her electricity went off while the furance was running. Heat had built up, so it melted...
How old is this furnace? When the "Energy Team" pays a contractor to replace a furnace, the contractor is responsible for the warranty work. Utilities normally handle the funds from Government sources but they pay the contractor full price. If *********** has paperwork, contact the company that installed the unit or go through the utility if they won't co-operate. As a side note. when the power is off, the gas also shuts off and enough residual heat to damage the plastic door would be really unusual.
Dec 30, 2009 | Tools & Hardware - Others
HVAC
Could be a voltage problem, could be the motor or the run capacitor or the start capacitor (if it has one). Gonna need test equipment to diagnose this one. Check the input voltage both at rest and during start/operation. Use capacitor tester to test capacitors. If all else checks good, it's the motor. I bet it's a power supply problem though if you have two different motors with the same symptoms.
Mar 30, 2009 | Tools & Hardware - Others
I want to add an air conditioner to my coleman evcon EB17B unit in my manufactured home. What would I need to get.
A kit is available through a Coleman Dealer sized according to the furnace you presently have installed. It should be installed by a contractor.
May 17, 2008 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
