Question about HP w1907 LCD Monitor
Only half of my actual screen image showing on my monitor, Factory reset messed it up in the first place so that didnt help any
    Problem Solver:
  • 5 Answers
Thealfords03 Hi I had the same problem but luckily I was able to fix it. If you press the menu button down for 10-15 seconds The OSD lockout scren will go away and you will have access to the regular menu. When I did this I noticed that on the menu screen, all the menuoptions would become highlighted one by one as if I press the " - " button on the monitor. This gaveme the conclusion that the button was the culprit. The button was not stuck because I could press it and it would go in and pop back out. So I removed the base plate (3 screws) and then I found that on bottom 2 corners you will see a **** on the black inner plastic (use a flashlight) Stick a flat tip screwdriver there and gently pull the black frame out. Once you do that you will gain access to the panel that hold the 4 buttons. Remove the plug and separate the board with the buttons from the black plastic base by prying the plastic clips back. If your faulty button is the " - " button like mine then gently pry the metal cap thats on the top of each button until you remove it ( If done carefully you can replace it by pressing the metal plate back on) Once you remove the metal plate you can remove the actual button. Look down to locate a thin copper concave circular plate. I used a metal polishing paste to shine the copper concave plate on both sides once shined place it back in the button and put the button inside then press the button downto ensure the button goes down and pops back up. If it doesnt then gently press the middle of the copper plate with the tip of a screwdriver and try it again. If the button goes down and pops back up you can place the metal plate over the button and press down to fit down in place. Reassemble and this will fix your issue. I was so glad I got rid of that annoying OSD lockout white screen once I did this technique. Good luck and post something if it worked for you!
Posted on Apr 06, 2011
Half my screen doesnt work on my compaq presario. How can I do a factory restore if I cant see the screen and what option to click
I would definitely not try to do a factory restore without a full screen showing. Are you saying that the external monitor does not work for system restore?
amazon seems to have replacement LCD screens for $51.93
http://www.amazon.com/COMPAQ-PRESARIO-CQ57-229WM-SUBSTITUTE-REPLACEMENT/dp/B005IUFKKW
Sep 25, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Jul 16, 2010 | AOC 7F 17" CRT Monitor
My W2253TQ developed a shadow across half of the screen (verticle)
I had the same problem and fixed it with a factory reset, which is done by pressing the menu button, selecting "setup" button, then continue pressing the autoset button on your monitor until "factory reset" is selected. Press the f engine button on your monitor and it will do the factory reset.
Oct 25, 2009 | LG Computers & Internet
Upper half of the monitor is darker
I would try an auto-adjust first see if that helps any, also you could try it on another PC to make sure its not your video card on your PC. Another option is to reset the screen to its factory defaults see if that does anything.
Sep 30, 2009 | Samsung SyncMaster 932B LCD Monitor
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
Apr 15, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Half of monitor screen shows on the projector.
You will need to set your computer to the correct display properties.
This you can do by either going to presentation mode.
Alternatively,
on Window XP you can simply go on to your desktop and right click > go to properties>go to setting> press display 2 and set the screen resolution as per your projectors resolution and enjoy.
( for information: display1 is the resolution meant for your computer).
Please do rate this solution and Thanks for usinf FixYa!
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Shows half screen only!
if you can't expand your screen size from the pulldown menu or vertically or horizontally center the picture one or two of the centering coils could be partially burned out. the monitor uses electromagnets around the crt neck to center the picture. varying the center controls apply or take away voltage from the coils to center the image. may be time for a new monitor
Jun 08, 2008 | Compaq MV 540 15" CRT Monitor
LCD monitor does not light up, and consequently, does not display any image (as some other digital cameras do) during the aiming and focusing processes - sort of prescanning the image - before the shutter...
to my knowledge digital slrs aren't supposed to show you the image on the screen before you shoot because the battery would get used up too quickly this is what the viewfinder is for and the lcd is purely there to tell you info on what the settings are and to view your pics after shooting, I have the 400d and its the same for that.Hope this helps
Sep 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
HP w1907 LCD Monitor Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
