Question about Maytag Dryers
I have an older model SD * maytag dryer. It stopped working sunday after i opened the door to stop a load. After i returned i went to push the start button and nothing happened. I checked the breaker box, switched were not tripped but i reset them anyway. I then unplugged the replugged the outlet, changed the setting, and checked the door several times to make sure it was closing properly. None of these things got the dryer working again. Any suggestions?
  • 59 Answers
Try replacing the door switch.
Posted on Apr 06, 2011
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model number PYE3200AYW stopped working and no light comes on when door is open
check the door switch:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 30, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dryer model LDE7304ADE stopped working. I stopped it mid-way through, closed the door, pushed the "on" button and it made a weird noise. I tried again and now it doesn't make any...
Door switch broke???
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Dryers
Dryer was working fine, and it just stopped, door switch is ok
Stopped turning and clothes still wet ? Was the timer still in the duty cycle ? Can I assume the door was properly closed. There is a safety switch on the door, open the door and find it. With the power off try pushing on the lever to activate the switch manually (with a tooth pick etc.) If you can hear a distinct click it is probable OK. If you want to test it with a meter you will need to open up most machines.
Jun 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Opener goes 12"+/- and then returns
havent heard any of yu say you adjusted the down force.
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
The dryer won't turn on
drive motor defective ,,,i can walk you thought,,,but i need a model number
Dec 30, 2008 | Maytag Dryers
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Dryers Logo
93 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
