Question about Pitco Frialator 35CS Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel going in
  • Pitco Frialator Expert
  • 684 Answers
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Posted on Apr 07, 2011
Pilot light goes out after a few minutes it seems t b overheating! It's a pitco freestanding 35C+ gas fryer
Check the oil temp and see when the pilot goes out. Is the thermostat shutting off at the correct temperature ? A low pilot flame could also be causing low millivolts, which can cause a pilot drop out.
Aug 04, 2016 | Kitchen Appliances - Others
How can you tell if the pitco fryer safety switch is bad
The safety switch is operated by extremely high temperatures. If the safety switch is bad, it will not shut off at extremely high temperatures.
Jun 02, 2014 | Imperial IFS40 Deep Fryer
Soot coming
Hi there. Check the gas pressure, it should meet the the nameplate required pressure, low gas pressure produce poor flame quality which results in soot formation.. The type of gas must also be compatible with the orifice sizes on pilot and burners. Check and clean as needed all soot formation on burners and fire tubes.
Regards.
Sep 23, 2013 | Pitco Frialator 35C Deep Fryer
Pitco fryer
Hi there!
Try to check first the incoming and running gas pressure, it must comply with the rating on the unit's nameplate.
Regards
Jan 26, 2013 | Pitco Frialator Kitchen Appliances -...
Pitco frialator excessive pilot flame
If you didn't figure it out already you lost the orifice on the pilot light. It's a little metal cup with a tiny hole in it that slips over the end of the gas tube in the pilot assembly. The orifice controls the size of the pilot light. Need to get a new one or find the lost part.
Oct 11, 2012 | Pitco Frialator SG14 Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco frialator and the pilot will light but when button is released after heating thermocouple, it just goes out. I've replaced the thermocouple but still the same. The pilot flame is in the...
Check if the unit receives the right amount of fuel as stated on its nameplate, if it does, check all wires for loose connections, Milli volt wont pass on loose wiring. If this does not correct the problem, you have to replace the gas valve, the main valve coil may be shorted that's why the pilot is shut when main valve is energized.
Apr 30, 2011 | Pitco Frialator 35CS Deep Fryer
My pitco frialator fryer's pilate wont stay lit
Check the thermopile, it should be free of soot or any form of dirt. Pilot flame quality must be good. Gas pressure should meet the requirement as stated on the nameplate.
Oct 22, 2010 | Pitco Frialator 35C Deep Fryer
Pitco frialator
Is it doing more than lighting the pilot light? Or is the only action is the pilot light coming on, then off?
I would need to know more spacifically which model you had. Here is a list of manuals on the manufacturers web site so you can see for yourself.
http://www.pitco.com/doc_lib.htm
If I were to look at your unit, I would first look for, and see if there is a sensor (sometimes appears to resemble a piece of coat hanger sticking through some ceramic) that the flames will heat. The warming from the flames generates electricity. The electricity keeps the gas flowing. It is a safety device to keep your home/business from exploding from a build-up of unburnt gas.
Make sure the sensor is being hit by the flame. If it is, and the flame still goes out, then it just might be bad. I would imagine it would run about $20 for a replacement part.
if it works, great! If not, then you are only out $20.
Apr 20, 2008 | Kitchen Appliances - Others
Pitco Frialator 35CS Deep Fryer Logo
249 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
