Question about Dryers
Replacing a 3 prong 220v with a 4 prong 220v. how to wire for 4th prong...? with a 3 prong 220v feed??
  • 59 Answers
You will need to replace the receptacle. can be found at most hardware stores. Just dont forget to shut off breaker.
Posted on Apr 06, 2011
I have a 4 prong tanning bed 220v and my appliance outlet at home only accepts the 3 prong plus such as the ones you see on a dryer. How can i get this converted to a 3 prong so that i can plug it in? Or...
It is because you tanning bed requires L1 and L2 (240V) and a seperate neutral, and a ground. You need an electrician to install a proper outlet. A dryer (years ago) was installed without a neautral. However per NEC electrical code even new dryers have to have 4 wires. Do not attempt to use on 3 wires !
Oct 02, 2013 | Coleman Powermate Premium Plus 6250W...
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 15, 2010 | Kenmore Dryers
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Jan 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Electric Dryer
If your dryer came with a 4-prong plug, do not change it. For the very reasons you quoted with the article, you may screw up the 110v accessories required of your appliance (like the clock or digital display). It is best to change the household outlet to a 4-prong type. Just make sure your wiring is correct. You will need a neutral on the 4th leg, which means you will probably have to run new wiring from the outlet to the distribution panel.
Jun 09, 2007 | LG DLE2514 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
