Question about HP StorageWorks EVA5000 (A7370A) Hard Drive Array
I'm considering buying a used HP Storageworks EVA5000. It has everything except for drives. I happen to have about 30 146GB drives that I can confirm are compatible (they HP-branded Seagate drives and their model number is listed in the EVA5000 firmware files). However I am shopping for some 300GB drives (Seagate) and I have concerns that because they are not HP-branded they may not work in this system. Can regular Seagate fibre channel drives be used in an EVA5000 or do I need to shop for specific HP-branded ones?
  • cliffwells Apr 06, 2011
    The EVA5000 is not a personal computer. It is a 168 drive fibre-channel storage fabric.
    Thanks for you response, but my question is specifically about using non-OEM (i.e. not HP, not Compaq branded) Seagate drives. It appears from my research that the EVA controller will flash the firmware on installed disks with a special firmware provided by HP. I know with vendors such as NetApp that you can use non-NetApp drives provided you flash them with the NetApp firmware yourself (technically tricky, but doable).
    What I'm wondering is if there is any similar path that will allow the EVA to use non-OEM Seagate drives (assuming the non-OEM drive is the same as some rebranded HP drive that is supported).
  • 2,632 Answers
Welcome to Fixya. If your concen is if you can purchase a Seagate 300gb you need to purchase a FATA hard drive that has VCS v3.020 or later. You cannot use FATA drives without having VCS v3.020 installed.
You can refer to the manual below for more info about FATA hard drives
You can download the VCS Sodtware on the link below
HP StorageWorks EVA5000 Software Download
If you will ask me which one to purchase i suggest you purchase the recommended by HP. So that in case it encounters a problem HP can support it. Keep on mind that products compatibility is buyers responsibility.
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 06, 2011
  • Rofel Lantican
    Rofel Lantican Apr 06, 2011
    Hi - with that questions is let me be honest with you. If you can install the firmware to non HP/Compact disk then most likely it would work but haven't tried to do it. Because the firmware is the software that allows you to use the disk to the device
    President:
  • 739 Answers
Hi
usually for personal computers, what is important is the type of hard disk and circuit board support is necessary to determine if they want to upgrade for example, if your motherboard has SATA ports so you can upgrade your hard drive using SATA hard disk, meaning you do not have here look at the brand because it is based on the support of your motherboard.
different about your problem, because it is devoted to a kind of restricted and limited support. mean you have to upgrade by using the specific parts and according to the type you need. is strongly recommended to use hardware that has been recommended by the supplier to resolve errors occur.
regards
Anytime I try to backup or copy a 33GB data file on a 40GB or 72GB Data cartridge, it requests for more data cartridge even after formatting the data cartridge prior to starting the process. Sometimes, the...
Because the DAT72 can copy 72GB with 2:1 compressed, and it's native capability is 36GB in the most. So you can try to copy less than 30GB data to it or try to enable the drive's compress mode.
Nov 26, 2010 | HP StorageWorks DAT 72 Tape Drive
Need to clean fan on HP Storageworks Ultrium 448 Tape Drive
here´s a manual
http://www.dectrader.com/docs/set3/emr_na-c00397852-1.pdf
Mar 30, 2010 | HP StorageWorks Ultrium 448 LTO 2 Tape...
We are trying to backup data files in tape drive 5 of 9 dirves but after backup by about 2 GB , there was a error , ''media full''. Product : ESL712E Product ID : HP Ultrium 2-SCSI
Tape drives are an antiquated backup solution. For less than $100 you can buy a 1 Terabyte USB 2 hard drive with space to back up even the most data-intensive systems.
Jun 11, 2009 | HP StorageWorks ESL712e Ultrium (AA934B)...
Adding additional drives to an MSA20 unit,
1- Turn Off MSA and server
2- Insert new disks
3- Turn On MSA first then server
4- Access ACU and new HDD will be listed
Nov 21, 2008 | HP StorageWorks MSA20 (0808736947138) Hard...
Tape Drive is eating my tapes
Besides buying a new one, if you have the knowledge, you can try to open the tape drive and clean it from the dust it may have. You should also clean all the rubber roller's that thouch the tape (when it is inserted) with a cotton swab with some alcohol.
Oct 14, 2008 | HP StorageWorks DAT 72 Tape Drive
DAT 72
here select your OS and then the latest firmware
Mar 02, 2008 | HP StorageWorks DAT 72i DAT Tape Drive
HP StorageWorks EVA5000 (A7370A) Hard Drive Array Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
