Question about Xerox Phaser 8560DN Laser Printer
It displays 'warming up' continuously and does not print
  • tedtec Apr 08, 2011
    It still shows 'Warming up' when first swiched on it goes through various percentages but quits at about 35%
    When I open various covers it reponds correctly
  • 2,574 Answers
Depending on how cold theprinter is, it can take several minutes for the printer to reach the proper setpoints. If the printer has stopped responding completely, open the Front Coveror a paper tray. The Display Screen should change from 'Warming Up' to 'CloseFront Cover to continue.' This will help verify whether the printer hascompletely stopped responding, or if it is simply in the middle of a processthat is taking a long time (warming up between thermal states and processing orcanceling large jobs can take several minutes).Test Internal Pages and Communication Cables to Determine theSource for the Printer Not Responding
  1. Power OFF the printer using the power switch located under the interface cover on the right side of the printer.
  2. Disconnect all communication cables to the printer.
  3. Power ON the printer. If the Control Panel continues to display 'Warming Up' or does not return to a 'Ready to Print' state after several minutes, contact support to place a service call. If the printer warms up and displays 'Ready to Print', continue with step 4.
  4. Print a Configuration Page. If the Configuration Page prints correctly, continue with step 5. If the Configuration Page does not print and the printer does not respond, contact support to place a service call.
  5. Re-connect the communication cables back in the printer. If the printer stops responding while connected to the network, there may be corrupt network information getting to the printer. Contact your System Administrator or contact support for assistance. If the printer is responding normally when connected to the network, continue with step 6.
  6. Send a test print from the workstation.
    1. Click on the [Start] button, then select [Setting], and then click on [Printers] or [Printers and Faxes]. The Printers or Printers and Faxes window will be displayed.
    2. Right-click on the required printer, and then select [Properties]. The Properties window will be displayed.
    3. Click on the [General] tab.
    4. Click on the [Print Test Page]. A test page will print.
  7. If the printer only stops responding after a file is sent, the file or print driver may be corrupted. Try to isolate the file and / or re-install the print driver.
Make Sure the Power Cable is Plugged Into a Good Power Source
Avoid usingmultiple outlet power strips as the printer requires a significant amount ofpower for initial warm-up. If there are other devices plugged into the samecircuit, there may not be enough power available. Plugging the printer directlyinto the wall is generally the most reliable source of power.Print the Configuration Page
NOTE: The ConfigurationPage can be printed to help solve printing problems and obtain the best resultsfrom the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Posted on Apr 06, 2011
  • 844 Answers
Welcome to FixYa!
Check the printer status first.
Depending on how cold the printer is, it can take several minutes for the printer to reach the proper set points. If the printer has stopped responding completely, open the Front Cover or a paper tray.
The Display Screen should change from 'Warming Up' to 'Close Front Cover to continue.' This will help verify whether the printer has completely stopped responding, or if it is simply in the middle of a process that is taking a long time (warming up between thermal states and processing or canceling large jobs can take several minutes).
Keep me posted.
Thank you for using FixYa.
Jas247
Posted on Apr 08, 2011
  • Jas Barinaga
    Jas Barinaga Apr 08, 2011
    Cont...
    Avoid using multiple outlet power strips as the printer requires a
    significant amount of power for initial warm-up. If there are other
    devices plugged into the same circuit, there may not be enough power
    available. Plugging the printer directly into the wall is generally the
    Keep me posted.
    Jas247
  • Jas Barinaga
    Jas Barinaga Apr 09, 2011
    As much as I am dedicated to resolve your problem, your printer is showing symptoms of a mechanical failure. Boot up / initialization failure. Some mechanical parts of the printer fails to function properly hence the printer does not proceed to go on "ready to print" state. The best thing to do at this point is to have it serviced to an authorized Xerox service center as it may require replacing some parts.
    You can contact Xerox at the number below.
    For Phaser & Network Printers: Toll Free 1-800-835-6100, U.S. & Canada
How To Fix HP Printer Error Code 0xc19a0043?
After installing GENUINE cartridges;
In some cases, a printer reset can clear the error message.
  1. Turn the printer on, if it is not already on.
  2. Wait until the printer is idle and silent before you continue.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    note: HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on. The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
If the issue persists, continue to the next step. Step 3: Check estimated ink levels The error might be caused by a low or empty ink cartridge. If an Ink Alert message displayed before the error occurred, replacing the ink cartridge(s) might resolve the issue.
Check your printer control panel for the Estimated Ink Levels feature. Control panel options vary by printer model. If you are unable to display the ink levels on the printer control panel, select your computer operating system below.
note: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low-ink levels, consider having a replacement ink cartridge available to avoid possible printing delays. You do not need to replace ink cartridges until print quality becomes unacceptable.
Oct 16, 2017 | HP Office Equipment & Supplies
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
When I try to print a copy, display says "warming
A well documented problem. Try following the suggestions posted here
Dec 03, 2010 | HP PSC 750 All-In-One InkJet Printer
My canon has an error b200 and it doesn't print or do anything I command.
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Nov 02, 2010 | Canon PIXMA MP620 All-In-One InkJet...
6110 officejet, power light blinks. display says "warming up" continuously?
Pls run the attached file to resolve the issue.
Description:
These all-in-one product firmware updates will resolve issues with receiving faxes, warming-up, certain printing issues and memory full messages with the HP OfficeJet 6100 series products.
Warming-up - Under certain circumstances when the all-in-one will display "warming up" indefinitely after pressing one of the "Copy" or "Scan" buttons
After downloading and installing this firmware update, the software will determine if the hp all-in-one would benefit from this firmware update and inform you of the results.
Installation Instructions :
Download the file "HpAiOFWUpdate2_2.exe" via http://www.printer-drivers.com/drivers/246/246484.htm to a local hard drive. Make note where (in which folder) the file gets copied.
The hp all-in-one software for the OfficeJet 6100 series must be installed on your PC before installing this firmware update. The OfficeJet 6100 series must also be connected to your PC and turned on before proceeding.
Locate the file "HpAiOFWUpdate2_2.exe" on your hard drive and double-click the file to install the firmware update.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 15, 2009 | HP Office Equipment & Supplies
IBM LASER24 printer - won't print - displaying '61 Error - please call for service'.
There is a bypass to this as I have this printer with the same problem.
When you power it on go to the button panel under the lcd and press
"online" then "continue" then "page eject" and it should begin warming up.
Jul 13, 2009 | IBM Network Printer 24 Laser
Not printing
hi
try ink management and continually do print test
Jun 22, 2009 | Brother DCP 130C All-In-One InkJet Printer
Prints 2/3 of the way, stops, continues, bottom is faded
It sounds like you need to replace Toner Cartriage
May 19, 2009 | Samsung ML 2010 Laser Printer
HP 7410 all in one-will not copy displaying warming
The display came back on and continues to print ok, but will not copy. Continues to say warming up when you try to copy. I read somewhere that we might have to change some board. We did not wany to put any money into it if we didnt know we could even get it working so we bought a new all in one by Brother. I own 3 HP laptops and the HP printers and have had many problems and their customer service is poor. Thank you for your help and your great site.
Filis
Nov 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
Xerox Phaser  8560DN Laser Printer Logo
374 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
