Question about Kenwood KAC-8403 Car Audio Amplifier
Kac 8403 Kenwood amp. The red power light is on. The fan and blue led stopped working out of nowhere. It just cut out. What could the problem be?
guly
  • 67 Answers
SOURCE: Amp not powering up correctly.
check transistor of the unit 1 or 2 tans. bad use a tester. the unit is overload protected. replace the deffecteve parts
Posted on Sep 19, 2007
  • 631 Answers
SOURCE: Amp does not power on, flickers when cable disconnected.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: Why does my KAC-8404 cut off at high volume bass?
My uncl had the same problem and he went back to the audio shop twice...Then called me...I discovered that the powr cords they used were not thick enough,giving the amp a low current to work on...but if you have the original cords you got when you bought the amp...it might also be a weak power supply....try playing the music while driving on a high speed or while reving the car to give more voltage from the alternator...If that doesnt work...come and shoot me please...im out,PEACE
Posted on Dec 29, 2008
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
  • 77 Answers
SOURCE: kac - 929 kenwood 1000 watt amp
Does it do it when car is not moving? If it does'nt then it is a bad connection in the amp itself or outside the amp. Check all your external connection well, it is easy to pass a bad connection up without knowing it. I recomend checking every connection, redoing the connections. Then you can rule that out and may find the problem. If connections don't fix problem let me know i'll be glad to help. I have my own amp repair business and people send me there amps from all over the U.S. Just send me a message and
I'll take you thru some steps to diagnose the amp if problem persists after connection checks. Good luck, hope to hear from you!
Posted on Aug 02, 2009
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Sep 17, 2007 | Kenwood KAC-8401 Car Audio Amplifier
My back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
Aug 08, 2007 | Kenwood KAC-8403 Car Audio Amplifier
Kenwood KAC-8403 Car Audio Amplifier Logo
55 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
