Question about Frigidaire Heating & Cooling
My son's landlord brought out a new Frigidaire 12,000 B.T.U. room air conditioner.He,(my son) plugged it in and the unit made a popping sound with a flash of light, followed by the smell of burnt plastic! Can you give me an idea of what might of happened?
  • 417 Answers
possibly sounds like a household wiring issue, if the unit was brand new and somehow got your 120 volt air conditioner hooked up to 220, that would cause that. You may have to ask some questions about who wired that plug that the air conditioner plugs into. It could be the other way around as well is the air conditioner 220 volts and the plug 120? Have someone check the voltage coming out of the plug. the voltage for the air condtioner and the wall MUST match. If its 220, that was your problem and your air condioner will need extensive service/replace. If it isnt, and the air conditioner was subjected to the lower voltage , it could have caused that as well and the circuit board fried, but hopefully the major components are okay check to see if your wall voltage and your air conditioner voltages are the same, they have to be, your unit will need service either way but hopefully the latter which is cheaper, and call a licensed electrician to check out that plug.
J
Posted on Aug 06, 2008
Why does my Mini-Split air conditioner emit a nauseatingly sweet odor and raise the humidity in my room when it's running. The vane is also wet a lot. Could there be mold in the drain pan/tray?
This is dangerous and the unit needs servicing. The unit could be the source of legionaires disease and other problems. I am guessing the servicing requirment is down to you not the landlord but contact him.
May 03, 2016 | Heating & Cooling
Frigidaire airconditioner ModelFRA18EMU2 made a popping noise now will not come on
probably a wire connection burned loose. it will make a popping sound.
Jul 13, 2015 | Frigidaire Energy Star Room Air...
Frigidaire FRA256ST2 window air conditioner unit quit working, breaker is fine and the plug reset only gets the unit to beep but not turn on
Have you recently plugged in another appliance (computer, microwave, etc)? The drain on your home's wiring system may not be allowing all appliances to run at once.
Some basic trouble-shooting guidelines can be found at: http://www.repairclinic.com/Air-Conditioner-Troubleshooting
Jun 21, 2012 | Frigidaire FRA256ST2 25,000 BTU...
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
Insufficient cooling with window air conditioner
The air conditioner should be big enough. It is hard to say whether or not the 46-47 degrees is right as you did not give a room temperature. The first thing to do before installing a used unit is to thoroughly clean it. Use your garden house to rinse both the evaporator and condenser coils. Also ensure the filter is clean. If the unit is still not cooling properly it likely needs a shot of refrigerant. Beyond cleaning the unit I would not recommend other do it yourself fixes.
Jun 27, 2010 | Heating & Cooling
Mr slim ductless ac choices
Try this Air Conditioner Sizing Worksheet from Consumer's Reports. It will help you.
I hope you find this information to be very helpful to you moving forward.
Please leave a rating. :-)
May 09, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Room temperature reads 95-99 degrees F, not cooling the room
one hose is the heated condensing air and one hose is the intake air. if this unit is not working correctly and u just purchased it take it back. if the landlord will replace it tell them. do not call a service tech to check this unit out if u know 4 sure the temp is set right and it continues to blow hot and the exhaust hose blows outside and the unit is set to cool you are money ahead to replace it. hopefully a landlord or recent purchase can bail you, you can find these units at home depot lowes and get them 4 about 400 dollars. hopefully it's covered somehow by warranty or landlord but the cost for checkout and service will exceed the cost for replacement. have you tried to unplug the unit leave it unplugged and try again. have u cleaned the filter. have you noticed ice anywhere. maybe a light that tells you the drain is plugged i don't wan't to get you're hopes down when you are burning up but check these things and let me know if u see any abnormalities. do you leave the unit running in hopes that you will come home and it works? check for ice is there air blowing constantly? if u dont get air flow you could have a fan thats out or its iced up. let me know.
May 25, 2009 | Haier HPAC99ER Air Conditioner
Error code A5 on Frigidaire 12,000 btu air conditioner
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Jun 11, 2008 | Heating & Cooling
Heating & Cooling Logo
131 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
