Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Intermittent losing internet
When I turn my modem off for 30 seconds to reset it to solve this problem, I sometimes have to turn the switch on and off several times because when I turn it on all four ethernet lights will turn on weakly and not go off and nothing happens until I turn it off and on several times until it comes on right.
  • 4 Answers
This issue drove me nuts for a while. I too have verizon dsl and use a verizon branded actiontec router (gt704wg).
The problem has to do with DNS configuration. Not exactly sure what the true root cause of the issue, whether with the Router / Firmware or on Verizon ISP side, but I figured out how to make it work.
DNS is what translates internet IP addresses such as http://198.105.192.72/ into recognizable Enlish language terms (http://www.espn.com). When you type espn.com into your browser, your request travels out to a DNS server somewhere which performs the translation into the numbered IP address and directs you to the appropriate website.
The problem you are having is that your requests aren't finding a DNS server to do the translations...
You can test this by trying: http://198.105.192.72/ in the browser URL hich should resolve to espn.com. If the website resolves, it means your internet connect is working and proves it is just a DNS issue.
If this is the case, then there are a few possible places where a faulty DNS configuration setting might be causing an issue. (Local PC, network router, ISP).
Try configuring your router to use static DNS : using the following address for DNS servers: 208.67.222.222 and 208.67.220.220
more useful info here:
https://www.opendns.com/homenetwork/start/router/
If that doesn't work, you can hardcode the same addresses on you pc by going to:
network connections > select the connection >properties > Internet Protocal (TCP/IP) > properties
Posted on Oct 04, 2008
    Champion:
  • 221 Answers
Your modem/router is not good. I used to have a Linksys-B router that did that, just gave up on it an bought a new one. You can probably find a new one for about $20-$40
Posted on Aug 06, 2008
Every so often, my internet seems to crash. On my pc it has a yellow caution sign over the internet. The data send/receive lights on my modem flash but the others don't when this happens. I try un
If it works sometimes ? when you unplug it then replugging it back in something is wrong with the modem / router or they might need to be reset .
or firmware upgrade
Reset linksy router b> One of the most common fixes for Internet connectivity often involves resetting the source of your Internet connection. If you have a DSL or cable Internet connection, you may use a Linksys router to get on the Internet. When you reset a Linksys router, you'll likely solve your connection problem.
Turn off the power to your computer's modem. Use the switch on your cable or DSL modem to disable it while you reset the Linksys router. Find the reset button your Linksys router. Most Linksys models have the reset option on the back of the router. Use a pointed pen or pencil to press in the reset button on your Linksys router. Hold down the reset button for approximately 30 seconds. Watch the lights on the front of the router. After you reset the router, power will get restored to the Linksys router. Once power's available, you can switch the modem back on. Reconfigure your router. After you reset your router, you'll have to log in and reconfigure your settings. The login name is typically left empty with your password as "admin."
Reset a Linksys Wireless Router b> You may need to reset your Linksys wireless router if you are having Internet connectivity issues or other networking problems. You can reset the router to the default factory settings, such as the default IP (Internet protocol) address, username and password. However, after you perform the factory reset, you can follow the initial setup instructions to replace your previous settings.
Write down any important settings you may have--such as the router's password--before you reset the router. Locate the reset button on the router. Some Linksys models have a reset button on the back side. Other Linksys models have a small pinhole you may need to access by using the tip of a pen or pencil. Press and hold the reset button for a minimum of 30 seconds to perform a factory reset on the Linksys router. The Linksys router should lose power. Power on the Linksys router to initiate the configuration wizard. Reconfigure any previous wireless settings on your Linksys router.
Hope this helps.
b>
Dec 28, 2012 | Computers & Internet
When i first set it up it was fine,since then the wires had been disconnected,when i put it all back the way it should go,i lose my internet connection on my pc,and on my nextbook,says i have connected to...
Make sure that the cable from the modem goes to the Router's Internet slot.
then the cable from either 1,2,3,4 can go in your computer.
then you need to turn OFF the router and modem for 1 minute
then turn ON the modem first, wait for 30 seconds.
Then turn ON the router, wait for 30 seconds. It shold work now.
Feb 27, 2011 | Cisco Linksys Wirelessn Router Black...
The signal is strong but there's no connection to internet
I have this problem sometimes. If you lose connection to the modem, you can't connect back to it, you have to reset the modem. Goto the modem, unplug it, wait 10 seconds, then plug it back in. Goto your connections, select yours, disconnect and then reconnect, wait a few seconds and it should connect. Hope this helps, let me know if it does or doesn't.
May 14, 2010 | NetGear WGR614 Wireless Router
I can't set my xbox360 to the internet
try running the diagnostic to see what the problem is. Could be a router / modem error or simply XBL is down.
Also reset your modem / router leaving the power off for at least 30 seconds then reconnect the router 1st, wait another 30 seconds then plug in the modem.
Feb 27, 2010 | Microsoft Xbox 360 Console
Netgear software, picks up wireless network then loses connection moments later
Netgear generally functions well. You may simply need to adjust the location of the router. Check the signal strength when you do have a signal. You may be losing a signal intermittently because the signal is weak. If your signal is "good" or better and the signal is lost without apparent reason, there could be a malfunction with the router itself. Check the router when the signal is lost and ensure the power light is on and the connection light is on.
If your signal is weak and you lose it intermittently, adjust the location of the router
If your signal is strong and you lose it intermittently, you may be experiencing a connection problem at the source or the power may be cutting out at the modem. The more likely answer is the source signal interruption. It is rare for a power supply to go bad in those.
Check the source connection INTO the router.
You can also reset the router. You'll want to unplug everything. Unplug the power supply from the wall AND from the modem and leave it unplugged for at least 2 minutes. There may also be a very small recessed reset button (the kind that you need to use the end of a paperclip to press). Press and hold that for 10-30 seconds to reset while it's still plugged in.
When you plug everything back in, plug the power in first (to the wall and modem), then connect the source cable. Wait until you have a signal confirmation light, then try to connect with your computer.
Last but not least, the connection problem could be with your computer. Try pluging directly into the source if possible and see how that works. Then try just moving close to the wireless modem and see how the signal strength is and if you lose the signal the same way. If there is a switch on your computer to turn on the wireless feature, make sure it's all the way on. Sometimes these are kind of stuck between 'on' and 'off' and that can cause problems.
I hope one of these suggestions helps you!
Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
I have DSL/verizon,modem 6100F i keep loosing my internet connection
Your problem definitely sounds like an intermittent connection problem. It can either be one of two things. #1. You have a defective modem, or #2 It's a network problem. I will definitely go with #2. Here's the thing. The problem you have is very very very common not only to Verizon DSL customers, but also to other Internet Service Providers as well. The best way to fix the problem is to understand what's causing the problem. There are two types of intermittent connection problems. The first is Intermittent Sync. You'll know if you have this problem because the DSL light will be blinking everytime you get kicked out. That means there's no internet connection, The modem cannot detect and establish a connection with the Central Office. The second is Intermittent route (which I know is you're problem), The DSL light is steady, but the Internet light almost always turns OFF or turns RED. The only way to fix this problem is to coordinate with Verizon. The reason is because the problem is outside your house. The long cable lines, the drop wire, the cables that passes through from the Central Office to your House can all be damaged, If that's the case, then a technician is required to go out and fix the problem. Don't worry about calling Verizon, this is a network problem and you won't be charge for anything. I know losing internet connection is very frustrating. Give your ISP a chance, they will definitely fix the problem if you give them the opportunity to do so.
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Motorola SB4200 Modem IP not working
You can always do the 30-30-30 reset as follows:
  1. When router is powered on, press the reset button and hold for 30 seconds. (Use a paper clip or something sharp)
  2. While holding the reset button pressed, unplug the power of the router and hold the reset button for 30 seconds
  3. While still holding the reset button down, turn on the power to the unit again and hold for another 30 seconds.
This should allow for a full reset of the modem. Once that's done, connect your computer to it with an Ethernet cable to access it's WebUI using the Default Gateway (192.168.100.1), or connect to the WIFI using the default SSID and Password that are usually written on the modem itself.
I hope this works!
Sep 07, 2017 | Arris SURFboard SB4200 Modem
Intermitent DSL/Internet Connnectivity 2701 Router
Hii,
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
For guest:
Do you see the power is also interrupted while loosing connection? If so try plugging the modem into different socket. Dont waste money for simple problems.
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
Jun 04, 2008 | 2wire (1000-000057-000) Modem
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
354 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
