Question about Cell Phones
I need exact part number of this smd code J:8
  • 410 Answers
Unlocking Phone Don't worry there isSolution to Unlock the Mobile Phone from the Security Lock....Use the MasterReset Code and Unlock the Mobile....I unlocked my mobile Nokia 6600 using theMaster reset Code,I got the Master Reset Code here http://www.superunlockcodes.com/unlocking-services/rs12wp6/and Unlock it........You Check Master Reset Code for Your mobile in the List..
Posted on Apr 06, 2011
What is the value of resistor 601
600 ohms
A resistor with a number code instead of a letter code is a SMD:
Surface Mount Device. You might have searched for SMD resistor code and got some hits.
The system for SMD resistors is:
1st value-2nd value-multiplier
6 - 0 - 1 following zero
= 600 or 600 ohms
603 would be 60,000 Ohms or 60k
6 - 0 - 3 following zeros
Mar 21, 2016 | Televison & Video
Tip
How to Calculate SMD Resistor Code
SMD resistor codes isdifferent from the normal resistor color code (color bands) you had seen in theelectronic circuit boards. Surface mount resistors is very much smaller in than the normal carbon film resistor and because of this the numbers andletters were stamped upon or printed on the top side of the component. Thosenumbers and letters have a meaning and you could use that as information tofind out or calculate the desire resistance values. Sometimes the resistors aredesigned in a very small until we have difficulty to read the code. Byusing a magnifier glass we could easily read the resistor codes. clip_image002.jpg clip_image003.jpgThere are two types ofsurface mount resistors used in an electronic circuit board-the 3-digit and4-digit code SMD. The first two digits represent the two digits in the answer.The third digit represents the number of zero's you must place after the twodigits. Theanswer will be in Ohms. For example: 104 which mean 10 0000 (4 zero's)and the final answer is 100k. Let's calculate the 4 digit SMD, 1182 which mean118 00 (2 zero's) and the final answer is 11.8k.
on Oct 07, 2010 | Televison & Video
Bose music system remote is inconsistent.
The notoriously unreliable SMD capacitors which Bose installed are long defective. That's just the start of your problems.
You'll need to replace those defective capacitors with much higher-quality units than the original.
Only a tech experienced with SMD work should attempt this repair.
Replacing the PCB will solve your problem for only a short time, as you are just getting the original standard junk again, but new.
Dec 29, 2014 | Bose & Wave& Music System
What are the eeprom codes for jvc tv lt-42x579, eeprom m16
The number of the memory IC will be printed on it. Usually, it will be in laser printing. When replace it, be sure to replace with exact number printed on it; otherwise, it won't work.
Will look somewhat like this. May be a DIL type or an SMD type.
Sep 15, 2014 | JVC LT-42X579 42 in. LCD TV
I need memory ic code for SONY TRINITRON KV-PG21P40
Hello
There is no code for memory IC. It is an 8 terminal IC, in which will have a number printed on it; usually laser printed. Check that number and buy the exact same number. That number is most important. OK.
Jun 19, 2011 | Sony Televison & Video
Fault 8 came on during the cleaning cycle and froze. I turned off the machine and restarted, unplugged the machine and restarted and still fault 8 came on
What is exactly this machine.What is the brand of the machine.What is the exact model number of this machine.Is the code F-8 or only 8.Please give more details.Keep updated.Thanks.Helpmech.
Feb 20, 2011 | Microwave Ovens
Need brushes and on-off switches for milwaukee 6140-6 hand grinders is this grinder obsolete?
I would need the exact model number and serial number to help but the brush number is 22-18-0710 and there could be a couple different switches. Either give the ser number (the alpha code) or you can go direct to Milwaukeeelectrictool.com and type in the model number 6140 on the page for the breakdown. it might be easier to let me do it. I worked there for 17 years and if you can't get the alpha code look at the switch and I would need a good description of it
Feb 20, 2009 | Milwaukee Tool Factory-Reconditioned...
Viewsonic VX910 CCFLamp drivers...
One and a half year later I know the solution :-). It is 2SC4672... sure!. DKQ* is in my Jaeger SMD-Decoder book (10.000 SMD - Demiconductor - Codes)
Common problem with inverter PCB. Caused by the damaged or loose 100nF (or some same value)
Succes. For me it is working.
TVMAN
Aug 09, 2007 | ViewSonic VX910 19" LCD Monitor
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
