Question about Miele Washing Machines
I have a Miele Novotronic W1926 washing machine and it is filling very slowly during the main wash on the cold setting. it does not fill slowly if hot setting it selected, but will fill slowly once it gets to the rinse cycle. I have check the cold water pressure and it seems to be fine and have also checked the cold water strainer at the intake. All checks out fine so far. Anything else I can check to avoid the repairman?
I have he same exact washer with the same exact problem. I have checked everything you checked as well. I took the cold side solenoid off and trouble shot it into a bucket and it seems that the solenoid is not opening like it should. Now I am stuck with whether its a bad solenoid or its not getting a signal. I'm thinking it is the solenoid but I will have to get some one with a multimeter to check the contacts to make sure it is getting a signal. If that's the case I will have to order a solenoid. It's simple to replace. Now I have to find out the part number and a place that sells it. I will try to keep this blog updated to help anyone else out that may run into the same problem.
Posted on Nov 18, 2012
  • David Shan Sep 13, 2013
    Any update with the solution? I have a same problem with my machine and like to have a fix.
2 Suggested Answers
rickyrt441
  • 4399 Answers
SOURCE: have a Miele Novotronic W1926 washing machine and
Thanks for choosing FixYa and welcome to the site. Where did he check the pressure at? You could have a water leak down the line somewhere. If he tested it close to the washer, it is possible he got a false reading. Do you have any error codes on your washer?
Posted on Apr 22, 2011
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Miele novotronic w918 keeps filling with water, whether turned on or off! Help!
Hello. Based on your symptom, I strongly suspect a defective inlet water valve if the power is removed and the unit keeps filling--that's your clue. Trash like sand or sediment might have somehow gotten past the fine water screens at the hot/cold hose connections and jammed the valve. Or, the valve(whichever one is allowing water in) could simply be defective. Now, if power is removed and the unit stops filling, I would be looking at the main control board as the likely culprit--probably a stuck relay on the board causing the issue. I hope this helps you.
Nov 07, 2015 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
208 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
