Question about Samsung CLX-2160N All-In-One Printer
  • Samsung Master
  • 4,338 Answers
The power requirement is AC 110-127 Power consumption is 300W. There is a Rating label on the unit. The Inverter may not be giving you enough current and/or frequency (hertz).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 22, 2008
My rv has an 8amp coffee pot. what size inverter do I need to buy to invert to 8 amps ac?
8 amp x 120 volts = 960 watts required. So a 1000 watt inverter will suffice. Better to buy somewhat larger. A variety of 1500 watts ones starts as low as $35 online to about $100 for a major brand.
Dec 11, 2015 | Inverter Heating & Cooling
What is the peak starting wattage and running wattage of a Samsung SD162Q fridge compressor, I am trying to run it ona 500 watt inverter with a surge peak of 1000 watts ?
You might need 3 or 4 times the average power consumption of a compressor. A 500W inverter is not anywhere near enough to start a fridge.
Feb 23, 2015 | Inverter Electronics - Others
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
After I hook up the power inverter to the battery, the AC product does not operate and/or the red FAULT light comes on.
It would depend on what type of AC product you'r trying t operate. While your load maybe only 1,000 watts, the starting inrush current may be too much for your inverter. Try turning inverter on, and see if it powers up. Try pluggin in something very small. Another possibility is the 12V circuit you're plugging the unit into isn't large enough to carry the current, and the incoming voltage is dropping too low for the unit to operate. A 1000 watt inverter is too large to plug into your cigeratte lighter unless you're only operating a very small load. Usually they are connected right to the battery. If you do this be sure to fuse it there , and run large enough wire to the inverter. You should probably have about a #4-#6 copper wire for such a large inverter.
Jul 12, 2010 | Black & Decker 1000w Power Inverter
Hi. I have a 5000 watt inverter in my truck. The alternator in the truck is a 150? amp alternator. I also have 3 deep cycle batteries (about 150 ah each) to run the inverter. Is this overkill for my...
A 5000 wat inverter is very large. Your alternator could not supply it alone without the batteries. The moderate to low usage is the key. Calculate the wattage of the load you want to connect. Depending on what else you're doing with the truck, lights, heater, air condition etc, you could probably draw somewhere between 1,0000-1500 watts on that alternator. Rember even if your alternator is rated for 150amps (large alt) it is not a 100% duty cycle. Alternators are usually around 50% duty cycle, so figure about 75amps continuous, or around 900 watts. That's considerably less than your 5,000 watt inverter. Buy a generator.
Jul 01, 2010 | Inverter Aims Pure Sine Wave Power...
I need to install a power converter in my truck.Can any one help me with the basics? Please get back to me. Keith
What is it exactly that you want to accomplish? It looks like this unit is powered by the electrical system of your truck, but if it indeed can provide 2500 Watts of output power, its input demand from your truck electrical system will be in excess of 200 Amps!!! You'll need some pretty hefty wiring to support that type of demand, and I doubt if your alternator can put out that amount of current.
Are you sure you want/need to do this - and run it off your truck electrical system?
Sep 22, 2009 | Xantrex Technology DPS350KB 2500-Watt...
I have a black and decker 1.7 cu.ft refrigerator its a 115 volts and 15 amp outlet and i am trying to put it in a semi truck. I am looking at a road pro 2500 watt. Do you think this will power it? And cool...
What wattage is the fridge Youy cant compare volts and amps withy watts.
If the fridge draws 2000 watts it wiull do the job but struggle as 2500 is the peak wattage and averages out at about 2000-2200 look at the back of the fridge. Just hope its about 15-1800 for effiecient cooling without strain on power source
Jul 28, 2009 | Electronics - Others
Need small microwave for inverter on houseboat
Look at the rating sticker on the oven and use the AC power rating as your guide. The cooking power of the oven is not important, but the power it needs from the AC supply is. Voltage times current is the supply power needed (watts), and you want an oven that will draw less than the inverter's continuous rating, less any power being used by other appliances.
For instance, a microwave rated for 120 volts AC at 10 amps needs 1200 watts. Your inverter would be OK with this as long as other devices aren't using more than another 1000 watts. You can't use the inverter's peak rating. That's only for brief bursts, like when the microwave first kicks on and draws some extra current.
Any mid-power (600 watts or so) oven should be OK.
Apr 16, 2009 | Emerson MW8627W Microwave Oven
Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
Samsung CLX-2160N All-In-One Printer Logo
163 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
