Question about Panasonic KX-TG5632 Phone
Phone shows line in use even though both handsets are off.
  • 81 Answers
Unplug the phone line to the wall if it sill says "line in use" there is a short on your phone and you will need a new one. If not there is a short somewhere on your line. Call your phone company to repair your line. Note the phone company will charge you for repairs inside your hose.
Posted on May 04, 2011
4 Suggested Answers
SOURCE: CORDLESS PHONE WITH TWO HANDSETS, RADIOSHACK 5.8 GHZ
Hello, I had the same problem with my line I called the phone company 2 times they checked the line on their side at the base and was unable to fix it, they also sent me new filters but that did not help either, they had to physically come out to my house to find out what the problem was. They checked my phone that was new and that was not the problem, they changed the box in my house and still the static and scratchy noise was still there, after 3 days they ended up replacing all the wiring from (outside my house) becuse it was way way old, now my line is clear as a bell. This may be your problem but you may have to sacrifice a few days. Good luck I hope this helps.
Posted on Jul 27, 2008
consultel1
  • 860 Answers
SOURCE: Both my handsets say Line in Use even though
Sounds like your telephone line is dead. Call your service provider to determine if its a problem on their end.
Posted on Dec 16, 2009
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
Good Morning. One of the handsets in my Uniden DSS7815+1 Cordless phone system fails to show any information at all, even though the handset can make and receive calls normally. The screen just sho
The circuitry has gone out in the phone, nothing more you can do, but replace it, might be able to find one on EBay, unless you can live with it that way.
Sep 27, 2017 | Uniden Lands Phones
My handset model is 5310 xprss music if i have open net on handset . handset show me only 7 set allow
If you are in network selection this shows the networks you may be able to roam on even though the handset is sim free the sim is still controlled by the network including what networks it will work off
Jan 14, 2011 | Nokia 5310 Cellular Phone
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
Phillips CD445 cordless phone - cuts out when pick up to answer
if you have had it a while chances r the batterys have had it even though they show full, try a new set, or even try standard batterys briefly while fone is not in charging mode to see if they work during a call.
Jul 30, 2017 | Philips CD4450 1-Line Cordless Expansion...
Both my handsets say Line in Use even though nobody is on the phone, no fax is coming through and no phones are off the hook.
Dec 16, 2009 | Uniden Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Panasonic KX-TG5632 Phone Logo
240 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
