Question about Frigidaire FDF50S Dehumidifier
The fan runs, but we get an A5 error. - Frigidaire FDF50S Dehumidifier
    Brigadier General:
  • 4,736 Answers
I think what you're actually seeing is an AS error. It's looks like A5 on the LED screen.
AS error means their is a sensor failure. So, before calling Frigidaire Tech Service
(800-444-4944), turn the Master On/Off Switch to OFF. Unplug the unit for 12 - 15 minutes.
This should give the unit ample time to reset itself. Plug the unit back in and turn the Master ON/Off Switch to ON. Now, set your controls as you normally do. If the unit starts up and runs as it should, the problem for now is solved. If it keeps re-occurring, contact Frigidaire Tech Service.
Posted on Apr 06, 2011
The fan on my bqdd122fw is not working check light comes on all filers are clean and tank is empty and secure
the fact that the fan wont run , is a tip off that (barring the fan has gottn stuck) the water collection bucket float switch has gotten out of adjustment , this might require a little trial and error to see just what posisition this little device needs to be in for the unit to run
Dec 17, 2014 | Dehumidifiers
What is A5 on our frididare dehumidifier?
Hello Friend, this is Z. I am happy to assist you!
If you are receiving an error code AS on your Frigidaire dehumidifier, it typically means that your dehumidifier is experiencing a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual appliance replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Jul 27, 2014 | Frigidaire FDL50R1 Dehumidifier
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Dec 21, 2013 | Frigidaire FAD704DUD Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Apr 16, 2012 | LG Dehumidifiers
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
Motor runs fan does not
you may have a stripped out fan unit, the fan motor runs, but the fan does not spin? my fan was plastic and stripped out there should be a flat spot the lines up with shafton motor ifit is round your should replace fan blade unit. i could not find one so i pushed tooth picks in between shaft an fan and glued them has worked for a couple months now
Aug 19, 2009 | Kenmore Dehumidifiers
Danby ddr401 dehumidifier reading 'E2' error code on screen.
Check the wiring that runs below the fan for nicks and cuts. I had this error code and was in the process of junking my dehumidifier when I noticed the wiring going from the capacitor to the compressor and a few other wires had somehow been chaffed and cut by the fan blade. I had already thrown the control panel away by this time so I don't know if replacing those wires would have cleared the code or not.
Jul 22, 2009 | Dehumidifiers
Fan runs all the time
I HAVE HAD A COUPLE OF UNITS THAT HAVE KEPT THE FAN RUNNING ALL THE TIME. I REPLACED THE CONTROL AND THAT TOOK CARE OF THE PROBLEM.
Mar 09, 2008 | Whirlpool AD70USS Dehumidifier
Frigidaire FDF50S Dehumidifier Logo
1,243 people viewed this question
Top Frigidaire Dehumidifiers Experts
Lawrence Oravetz
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
