Question about Hayward Navigator Pool Cleaner
My navigator is like brand new and strong suction, but it just won't move around.
  • 640 Answers
If you are getting suction through the cleaner, but it is not moving around, you probably have wings or shoes improperly installed. If the pool cleaners shoes look worn or are not installed properly, this will happen. A copy of the users manual is below. Check to make sure that they are installed properly.You might also need to adjust the rear tension flap. Finally, even though you think your suction is good, make sure that there are no obstructions or leaks that would cause movement failure.
Posted on Apr 12, 2011
My hayward navigator doesn't walk
not a problem with return pressure. navigators run off suction pressure. ensure proper suction from skimmer or designated suction line. then check the hose attached to navigator. put a new hose on, if this works then the hose was issue.....if no difference then replace the navigator
Mar 07, 2014 | Hayward Navigator Pool Cleaner
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
Navigator pool cleaner just skims the bottom of the pool and does not sit on the bottom, it moves all around the pool but appears to be floating a little. How can we fix this so it will sit and move on the...
Interesting question. Do you have the special Lead Hose, the one with a colored cuff attached to the Navigator itself? Other causes can be, too little or too much hose, a pinhole leak in one of the hoses above water causing the hoses to float, not enough suction on the Navigator. You didn't say if you have the Navigator plugged into a skimmer or in a dedicated suction port in the wall. I would first try increasing the suction to the unit and see if your problem doesn't go away.
Sep 03, 2011 | Hayward Navigator Pool Cleaner
Brand new Aqua Critter, won't move at all? Checked filter, checked hoses? Still will not move? Now what?
It looks like my cleaner. While it is hooked up to the filter, lift the unit, keep the suction side under water and flip it over. The feet should be moving. Feel for suction on the inlet on the underside.
There is a waterwheel inside the suction. Is it rotating? Is the suction hole clear, sometimes stones, acorns or other solid items get stuck in the suction that stop the water motor.
If there is something stuck inside or if the wheel is not moving, on my unit there are a few screws that can be removed to inspect inside. Naturally before doing this, disconnect the cleaner, drain it and take it to a location where it can be partially disassembled to inspect.
Gary
Jul 10, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Navigator gets hung up at curve going up the pool walls. It has plenty of suction, new rubber feet, clean pool filter running at 3000 rpm,turbine is moving freely with no debis, all suction going to...
You have check all of the things that I would usually recommend when these pool cleaners are moving properly. My additional suggestions would be to make sure that your hose is not too short (adding lengths of hose if necessary) and to check for steering failure. Check and clean your rear screen, make sure that your cone gear is operating smoothly in all directions, and clean, repair, and replace (if necessary) your gear box.
Feb 06, 2011 | Hayward Navigator Pool Cleaner
Navigator sticks to the bottom of the pool and won't move. I replaced the turbine and the A frames are good. Will new feet help? the current ones are worn.
The feet might be the problem, but more than likely, you have too much suction on the pool vac. There is a suction gauge that comes with all new cleaners and most pool stores will have them available (maybe as a loaner even) to allow you to adjust the suction to your pool cleaner.
Try adjusting your suction to your cleaner to reduce the amount of direct suction to the cleaner to see if it operates, but if your feet are worn, you should definitely replace them.
Dec 05, 2010 | Hayward Navigator Pool Cleaner
MY NAVIGATOR IS MOVING VERY SLOW AND GETS STUCK OFTEN ON THE DRAI
Take it apart and make sure it doesn't have trash in the wrong places or broken gears, also check the other end of the hose and make sure you have suction at the unit.
Sep 13, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Sep 05, 2009 | Hayward Navigator Pool Cleaner
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Hayward Navigator Pool Cleaner Logo
416 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
