Question about Sony PVW-2600 VCR
Sony Betacam SP PVW-2600P wont play tape. Tape doesn't seem to load properly. Lace up doesn't finish with its usual defining 'click' noise. Displays partial picture at first then disengages and displays error 05 or error 03. Rob
  • rob1547 Apr 07, 2011
    Hi aplug
    Have inspected the laceup transport paths and there's nothing obviously blocking or obstructing the mechanism. The other thing that may provide a clue is the tape will load into standby mode fine but its when I hit play or FFWD that the error occures.
    With the top of the machine off I can observe that when I hit play slack tape starts to occur just after the pinch roller to the left of the play head. And when I hit FFWD this is worse.
    Rob
    President:
  • 1,961 Answers
There is a problem on the mechanical loading system of your recorder this is often cause by a dislocated timing gears some are cause by a foreign objects that blocks the movement of the mechanism. to resolve this problem open the cover and have a close look to the mechanism remove any objects that might block the mechanism.Re align the timing gears replace any brocken/damage gears.be very careful when dismantling the mechanism this task is not easy if you do not have any background in electronics I would suggest to consult a skilled technical personnel to do the job for you. good luck and let me know if you need further assistance..
Posted on Apr 06, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Apr 07, 2011
    Thank you for that information.obviously,the problem is on the problem is on the gears that rolls in the tape.there are two gear that works when playing a tape.the gear that rolls out the tape and gear that rolls in the tape.check the gear that rolls in the tape this must faulty causing the slacking of the tape.It might be a broken gear or a loose belt...replace them..
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Jul 14, 2009 | Sony Betacam SP Small Videocassette 30...
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Sony PVW-2600 VCR Logo
231 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
