Question about Brinkmann ProSeries 810-6330-W Grill
The gas flow metal pieces fell off how i replace them
    Brigadier General:
  • 4,736 Answers
Could you be a little more specific about the "gas flow metal parts" that fell off?
Posted on Apr 06, 2011
Cub cadet xt1enduro. A small piece of plastic 1 x 1/4 fell off the gas container nozzle and went into the gas tank. Does this need to be removed? Do I need to remove the tank to do it? If so, how?
Hey Cathy...
Personally, I would not worry about it.. unless it starts blocking the fuel flow out of the tank. Since its part of the gas container it should not cause a "melting/disintegration" issue.. its no biggie...
Sep 08, 2017 | Cub Cadet Garden
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
Inside the walking foot a piece of metal broke
I would contact the manufacturer and ask about it. Maybe a replacement part is available.
May 31, 2010 | Sewing Machines
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
this sounds like the needle guard it is usually held on by the same screw that holds the needle clamp it should fit so that it comes across the needle at the front to stop your fingers being sown but not interfere with the needle try turning by hand before turning back on.
Jun 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Paslode 900420 piece fell out
Be sure to remove the metal nose piece that covers the lockout bar when assembled. It may be stuck to the other half of the gun. Replace the bar and the spring and put the metal nose piece in its position over the lockout bar. At this point the metal nose piece will be on the opposite side. This will allow you to replace the 2 halves carefully so as not to loose the spring.
Apr 23, 2009 | RTO PasLode 900420 Impulse Framing Nailer
I have a gas system model# RFN28TA that is natural gas.
Yes but you must change the valve from natural gas to a propane gas valve, that's a little bolt shaped metal piece that has a hole in it to restrict the flow of gas. You should probably should take it to a professional
Jan 12, 2009 | Desa International Heating & Cooling
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Brinkmann ProSeries 810-6330-W Grill Logo
50 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
