Question about Sony STR-DE697 Receiver
Sony STR-DE697. Remote will not communicate with amp, has new batterys, amp is fine otherwise
    Brigadier General:
  • 8,546 Answers
Make sure the receiver's remote 'eye' is not exposed to high infrared energy from other sources, like the sun.
Try this advice:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Find new or replacement remotes:
http://remotes.com/store/codes_original.html
or eBay: search for "(model) remotes", check the 'include description
Posted on Apr 06, 2011
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
Will not turn on after electrical storm
Check your fuse inside must be blown on power section.
Sep 04, 2011 | Sony STR-DE697 Receiver
Universal remote programming code for str de697 reciever I am trying to program my ATT uverse remote to operate this reciever.
Here are the list of Sony remote codes :
5017, 5023, 5028, 5029, 5030, 5031, 5032, 5033, 5095, 5096, 5097, 5113, 5117, 5121, 5125, 5129, 5133, 5134, 5136, 5146, 5162, 5163, 5169, 5170, 5171, 5172
Here is how to program the remote.
  1. Turn on the Receiver.
  2. Press and hold AUX and OK at the same time.
  3. Release both the AUX key and the OK key at the same time. All the Mode keys should flash twice.
  4. Enter the four digit setup code and the AUX key will flash three times indicating correct entry and return to normal operation.
  5. Point the remote at the Receiver and press the power button. If it turns off the receiver it is now programmed. If not Repeat steps 2-5 until the remote turns off the unit.
Good Luck,
Robert
Feb 27, 2011 | Sony STR-DE697 Receiver
Can I hook up a fisher (EQ-961) to a sony
Yes, see the other request you posted:
http://www.fixya.com/PostComment.aspx?thid=4196867&prdid=0&ctgid=109
Feb 23, 2010 | Audio Players & Recorders
I have a problem with Sony STR-de697. the problem is that no means no sound is heard on AM / FM and anywhere else, please for assistance. thanks
AM and FM have mute circuit that no signal comes thru antenna (hope you installed external antenna ) no sound generates at all ? with computer terminolgy "garbage in ,garbage out"
Additonally , If this happens on CD,DVD or casette as well
What about speaker selector? A or B ,(based on your speaker wiring ) is properly selected or not?
Jan 10, 2010 | Sony STR-DE697 Receiver
Need instruction on how to set up to surround sound.
Go to www.sonystyle.com click on "support" Type in your model # and you will get more information the you could ever need on that receiver! Including the manual. Hope this helps!
May 22, 2009 | Sony STR-DE697 Receiver
Sony STR-DE 697
Hi there. Sounds like you may have some wires that go from your stereo to speakers touching.Check all wiring and make sure none are touching especially behind you amp...
Mar 29, 2009 | Sony STR-DE697 Receiver
Sony STR-DE697 7.1 - Needs Dolby Prologic IIx
Hi Plasie, unfortunately you cannot upgrade this level of electronics easily, nor cheaply. Updating the whole rig is you only answer
regards
Graeme
Mar 21, 2008 | Sony STR-DE697 Receiver
Channel cut out
Stereo Tech: Sounds like you definitly have a broken solder connection on the main PC board. A bad solder connection is tricky to find somtimes if one is not familiar with exactly what it looks like (kinda like mt st helens with a ring around the top) if you attempt this yourself DO NOT MAKE A SOLDER BRIDGE you will open pandoras box. Good luck
Jan 08, 2008 | Sony STR-DE697 Receiver
Sony STR-DE697 Receiver Logo
330 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
