Question about Samsung Televison & Video
When i turn the tv on, the lamp light flashes and my tv makes a high pitched whirring sound. does the lamp simply need to be replaced?
    Scholar:
  • 125 Answers
Thaat is probably right. Pull the lamp assembly out and check for physical confirmation of a bad lamp. Remember though that even if it looks good it may still be bad. Another possibility is a color wheel problem but try the lamp first.
Posted on Apr 06, 2011
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a Samsung HL-R5677W TV set and now there is no picture at all. Every time you power on the TV the green light flashes and you hear this sound that repeats itself. It sounds like a camera flash, low...
I have a few questions which will determine what your problem may be.
Did or does the set make a high pitched fan like sound or a high pitched whine?
What have you examined so far?
As far as a lamp it is unlikely it will cause such a sound but if you remove it look to see it is intact and not shattered.
Let me know
SD TECH
Sep 23, 2011 | Samsung HL-R5677W 56" HDTV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
Green light flashing, bulb will not turn on, green light sometimes goes to red flashing light
check the lamp. does it have bulges, black spots, flaking or fogging? if so replace it. aslo if the screen on the side is clogged with dust. if the lamp is ok, check the colorwheel. if you don't hear a high-pitched whir when you turn it on, the colorwheel motor is bad. replace the colorwheel. check the fans, too.
Mar 23, 2010 | InFocus X1 Multimedia Projector
Will not turn on, red light flashing next to the menu button
if the fans don't turn on, they may be bad and needs replacing or rewired. if the fans turn on but not the lamp, the colorwheel may be bad (listen for a high-pitched whir when you switch it on. if no whir, replace the colorwheel). if the colorwheel is ok, replace the lamp.
Mar 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
My bulb went out in my x1a so i replaced it now it
is the led on the top of the projector blinkng at all? if there is no led lit, the fuse on the power supply may be blown or the power supply itself needs replacing. turn the projector on. you should hear the fans and a high-pitched whir. if you don't hear that whir or it sounds like a noisy motor, the colorwheel needs replacing. if it sounds good but no light, make sure you have the correct lamp. the x1a takes the sp-lamp-009 lamp. it should have 2 white wires, each at opposite ends of the plug. if you have a lamp with a red wire and a white wire, you have a lamp for an x2. also make sure the lamp door is closed completely. if the door is closed (hitting the switch), the lamp is correct, the led is green, and the sounds are good and it still does not light, the ballast is bad and needs replacing.
Sep 23, 2009 | InFocus X1a DLP Projector
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Light went out
then it may not be the lamp, but make sure you have the right one (sp-lamp-021). also check to see if the colorwheel is moving. turn the projector on and listen for a high-pitched whir. if you don't hear one, the colorwheel needs replacing. and the lamp won't light without the colorwheel spinning.
Jul 17, 2009 | InFocus ScreenPlay 4805 Multimedia...
Unit powers on but green light flashes and no projection
if you hear a high-pitched whir, the lamp or ballast may be bad. if you don't hear a whir, the colorwheel is bad. the lamp won't turn on without the colorwheel.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
Televison & Video Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
