Question about GE WSXH208A Front Load Washer
We had a repairman in who said our washer motor was shot. we just replaced the motor and it worked for about 15 minutes, than it stopped spinning or agitating. it fills with water and drains water but it the drum will not move.
  • 2 more comments
  • phil_ackers Apr 06, 2011
    I need to understand more. I don't know what you mean by the transmission or how to replace it then..
  • phil_ackers Apr 07, 2011
    This is the quality of information I was looking for...thank you very much. As it turns out it looks like it is the speed control that needs replacing. Thank you so much for your time and expertise on this.
    Great information and great detail. As it turns out, the speed control was at fault - motor was fine.
    Great level of detail and care went into the response. This service was well worth it!
    President:
  • 1,554 Answers
There's no transmission in this machine if this is a front loader. Verify if the motor is getting power from the motor speed control. The motor should at least hum if it is good and getting power from the speed controller. It is likely that the drum is restricted or the tub bearing is worn and seizing resulting in the burning out of the motor. Remove the drive belt and turn the drive pulley manually on both directions to check it for restrictions.
Check power right at the motor winding terminals if the motor is not humming at all. The motor has likely burnt out again if its getting power but not humming at least. Check the wire harness connecting the motor to the speed controller if no power is getting to the motor winding terminals. The motor speed control is dead and needs to be replaced if the wire harness is good.
Let us know if you need further advice but indicate the exact model number of the machine. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Apr 06, 2011
  • 10,319 Answers
The transmission is at fault and not the motor
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Kenmore Oasis HE 27082 Displays "LD" error falsely
Since that you let repairman do twice and didn't fixed the problem, I think your washer have still warranty from the vendor. and they repair it free.
Please verify the panel board of the machine maybe got grounded in the wiring or got wet. How ever you can do that in your own you should consult the repairman on that matter. however the two repairman did not resolve, so its better to bring the washer's to the vendor. im sure they can fix the issue or you will be enlightened by their valuable suggestion and solution.
may this help
melnavz
Oct 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Ge washer will not spin
is it leaving water inside,if so the pump in the bottom has something longed in it.it will be about the size of a fist with black or white hoses going to it
Nov 14, 2008 | GE WHRE5260E Top Load Washer
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model...
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Jun 24, 2008 | GE Washing Machines
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washin machine not spinning
Your repairman is correct. The problem is a rusted spin bearing just under the tub. It is only in use during the spin cycle. Parts are about 50-70 bucks but it's a very difficult job and out of the range of the average do-it-yourselfer. Try to use the machine almost every day to prevent the bearing from freezing up. That way you can get a few more months use out of it before replacing it. If it does freeze up, try to turn the basket manually. It won't move much when its stopped because of the brake. Your repairman probably turned it during the spin cycle by defeating the lid switch.
Nov 06, 2006 | Maytag Atlantis MAV6451 Top Load Washer
Error code F11 and orthers
gailo, F11 is a serial communication error. Communication between the central control unit and the motor control unit cannot be sent correctly. Possible solutions: Check the harness between the two boards for loose connection. Driver motor, main board or motor control board may be bad. I have come across a number of these with loose connections and bad main boards. Put it into a test by pressing drain/spin on the left side. Then press the spin speed button on the right until no spin is lit. Then press the pre-wash button on the right 4 times until 00 comes up in the display. You are now in the automatic test mode. Let it do it's thing about 15 minutes and see if the error comes again. Catriver...post back.
Oct 29, 2006 | Kenmore 45981 Washer
GE WSXH208A Front Load Washer Logo
223 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
