Question about Kodak EasyShare C143 Digital Camera
The lens is stuck open on Kodak Easy Share C143 camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 06, 2011
Kodak easyshare c1450 lens stuck open lens obstructed
You need to remove the batteries and remove the memory card. Then reinstall the batteries. Finally, press and hold the "ok" button, the power on the camera. This is a factory reset trick. It fixes approximately 40% of all error messages on the KODAK EASY SHARE CAMERAS. But of course, no one is gonna be kind enough to help somebody out, they just want to take your money!
May 19, 2012 | Kodak Genuine Easyshare C1450 Lens And Ccd...
When i turn on my kodak c143 camera the screen goes blank what do i do?
If the lens go out and in,
Take a picture and download to PC
If the picture show blank. You need replace the CCD lens.
You can buy on
http://www.ebay.com/itm/GENUINE-KODAK-C143-LENS-CCD-SENSOR-REPAIR-PARTS-/170668440537?pt=Digital_Camera_Accessories&hash=item27bca1bbd9
replace it your self if you have tech knowledge. Is ease but you need patience
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 27, 2011 | Kodak EasyShare C143 Digital Camera
I need a cd to install kodak easy share c143 to my computer so i can download pics from the camera to my comp
download the necessary software from this link. Make sure to use the right platform (operating system) and copy it to a cd.
Regards.
Plz. dont forget to rate this suggestion
Jul 15, 2011 | Kodak EasyShare C143 Digital Camera
Bagaimana cra mentransfer file foto dari kamera kodak easy share c143& softwarenya pke ap
How cra file transfer photos from the camera kodak easy share C143 and software pke ap
Jun 30, 2011 | Kodak EasyShare C143 Digital Camera
Driver for kodak easy share c143 digital camera
Having gone over a month without a response to my query, I assume my suggestion to use a card reader eliminated the need for a driver.
Jun 22, 2011 | Kodak EasyShare C143 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
Lens is stuck
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Kodak EasyShare V1003 Digital Camera
I have Kodak Easy Share CX7430. I have put in new
Enilra, sounds to me like you might have the button that takes the photo stuck in the down position. Without turning on the power, put you finger on the button and press down on it while you move wiggle your finger around. Get a good look at the button and see if You Can See If The Button is returning to the UP Position. Withour seeing your camera in person this would be my guess.
Feb 19, 2009 | Kodak EasyShare One Digital Camera
Kodak EasyShare C143 Digital Camera Logo
127 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
