This tv is rear projection colors way off and images double. red area in upper left hand corner. Lost remote in resent move I am very handy. Need site to order parts and location in tv where problem is. Your help would be appreciated. thanks Eric
  • 2,098 Answers
Hi Eric,
This symptom indicated that you're convergence board inside was already gone bad. You must look first for bad solder joints(crack/dried/cold solder). Work in the brightest area or used table/portable lamp and magnifying glass to spot it in that board. Once found, re-solder it.
If the above steps didn't cure the problem, you may replace the convergence IC's and some of the resistor around to back the unit to normal again.
Let me know the model n0. of your unit to assist you further.
Jdvillanueva
Posted on Apr 06, 2011
Upper left corner of tv is double image with pink and green
Press Menu on the remote If you see double green, red or blue letters and a part or all of picture looks double, this means the convergence circuit is the problem. A repair like this could be $150.00 and up.
If you're an electronic savvy, you can replace the two chips (stk392-***) yourself.
In this case the 2 black big convergence (both with same part#) chips need to be replaced and without the model# I can't tell which ones they are but they could be one of the following: STK392-110 or STK392-120.
Sometime the resistors around the ICs go bad and you inspect them and measure the with an ohmmeter.
Best of luck
www.aaatvservice.com
May 06, 2012 | Hitachi 51F710 Rear Projection Television
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
Red shadows in 48" JVC rear projection
Well you better be pretty handy with a soldering iron. The convergence output IC's need to be replaced. These are large plastic pack IC's with 18 or so pins that are soldered on the underside of the circuit board. These IC's are mounted to large metal heat sinks.
Jun 17, 2009 | JVC AV-48WP30 48" Rear Projection...
Double image on my Sony KP 43t90
  • Screen looks 3D
Feb 22, 2009 | Sony KP-43T90 43" Rear Projection...
Bowed flickering green screen, black on bottom
  • Screen looks 3D
Jan 25, 2009 | JVC AV-48WP30 48" Rear Projection...
Hitachi 53UDX10B PICTURE DISTORTION
projection screens are prone to screen burn ,this is caused by the same image being displayed for a long time ie nick jr image in the corner,also check ther are no magnets close to the tv as this will cause distortion,ie speakers etc,hope this helps
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Red is distorted on upper left corner only
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
