Question about Dishwashers
I have an electrolux dishwasher model # EIDW6105GSO. All panel lights are flashing, cannot reset, tried cycling power, all lights just keep flashing
  • 13 Answers
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Posted on Aug 20, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
I had the same problem and followed rstecher and his solution. Removed the kick, light flashing was saying a leak was detected. Tipped the DW on it's side, have plenty of towels ready because the pan will be filled with water. Make sure power is off. Removed the pan and every single one of the clamps was loose. Tightened all the clamps at least 4 complete turns. Dried everything so the sensor wouldn't pick up any water. Put the pan back on and it worked perfectly! Thanks rstecher!
Posted on Jun 09, 2010
Is there a reset button on frigidaire dishwasher model fdb710lcb0
Mate im in Australia and don't know if the Frigidaite is the same as the Electrolux/Westinghouse but you can try this I posted a day ago:
On the Westinghouse and Electrolux dishwashers to reset a program that it defaults too you start the program and once initialised then press and hold the program button for about 3-5 secs. The panel will beep and all the lights will come on and not flash. From there on using the program button you select the wash cycle you want
May 28, 2016 | Frigidaire Dishwashers
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
How to fix error code leak detected on Electrolux EIDW5905JS0A?
Good Afternoon Friend,
I understand you have an error code of a leak detected on your Electrolux dishwasher, model# EIDW5905JS0A. I also see that your drain was clogged to start and after you cleared the clog was when the error came up. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux Dishwashers
Electrolux PLD2560LCC1 lights flashing
I understand that you have flashing lights on your Frigidaire dishwasher, model# PLD2560LCC1, and will not start the cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try running the cycle again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire Dishwashers
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
My electrolux dishwasher model EWDW6505GS0 will not turn on. The electronic display only indicates "Welcome" for a split second and then goes out and nothing lights up on the panel and cannot get it to...
Good Afternoon Will, thank you for allowing me to assist you!
How long did you leave the breaker off? It is important to wait roughly ten minutes and then your dishwasher on. If resetting the power does not correct the issue, then it sounds like your dishwasher could possibly be experiencing a communication error with the control board/panel or a potential wiring failure. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jan 11, 2014 | Electrolux EWDW6505GS Fully Integrated...
Electrolux esl 6226 not working beeping sound and light flashing
Hello Eamonn, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 12, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux EX600 Dishwasher loosing power during wash cycle
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
Feb 26, 2013 | Electrolux Dishwashers
I have an electrolux dishwasher model #=EIDW6105gS0. All lights are flashing on the console and will not let me select any of the modes...will not run at all. Is there any way to reset? I have tried...
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Apr 06, 2011 | Electrolux Frigidaire Professional Series...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Owen Barnes
