Question about Kohler Electrical Supplies
I have a Kohler 10RY propane generator, 10 yrs old. Starts and runs for 10 seconds or so then revs erratically before throwing out a fault..probably an overspeed fault. Has done this intermittently for a few weeks. Now it faults all the time. Recently did valves, plugs and wires, any thoughts? I'm off grid and use the G most days for up to an hour. Valve adjustment and plugs and wires were done since this problem started and the unit has run since that work.
  • 116 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
try to unplug the device and then again plut it after some 5 minites and reset it.
Posted on Oct 09, 2008
protek480
  • 1714 Answers
SOURCE: unit shuts down from overspeed fault
The engine throttle control is out of adjustment. It needs to be set based on the generator frequency
(60 Hz).
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: I have a Kohler 12RESM1 propane generator with oc/uu code
I am getting the same exact problem and errors with my 12RES Kohler generator. It will try to start using a remote switch but fails. Then it will start using the switch at the generator. The error code it comes up with using the remote start switch is usually OF or UU. It is less than a year old. Can Kohler Help??? Dave R.
Posted on Feb 20, 2010
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
SOURCE: I have a new Kohler 12kw res generator on propane - backfiring
did you put the propane orifis in and unplug the spark wire
Posted on Sep 20, 2010
WHAT WOULD CAUSE A AUX FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Aux fault can be many things, if it failed to start you may get it. Try reseting and manually starting. See if it re-occurs while it is running or does it ever start and give error. I have seen this generator by a coolant level sending it is an auxillary fault
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
14kw kohler propane generator-sometimes does not start, put battery jumper on and it starts. Battery is new, but had the same problem with the old battery.
The battery charger is defective, as you can start it by jumping it off means it is just a low battery. without it running measure battery voltage, it should be around 12V then plug the charger back in, it should climb to around 13.8B with a good battery. If not have the float charger checked.
Jan 25, 2013 | Kohler 14resa 14kw Home Emergency Backup...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
My 18RESL Kohler Propane Generator ran for 8.5 hours and shut down for overspeed. later it started up again and shut down for under frequency. Now it won't even turn over. Where do I start. I checked...
You have to reset it because it locked out on on under frequency. Just pullout the fuse on the control panel and then reinstall it a couple of seconds later. Now it will reset the fault codes. Hope that helps.
Dec 02, 2010 | Kohler 12 kW Emergency Power System -...
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Jan 25, 2010 | Kohler 12 kW Emergency Power System -...
Kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Oct 09, 2008 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
349 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
