Question about Garden
How do you take the red cover of a rover i4000 lawn mower so I can change the pull cord
  • 45 Answers
SOURCE: Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Posted on Sep 27, 2008
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
  • 302 Answers
SOURCE: cannot find the sump plug on rover i4000 push mower
It should be under the deck above the blade. Look for a square headed pipe plug. hope this helps you
Posted on Jan 17, 2010
How to remove the recoil top cover on rover i4000
A couple links that might help you...
Cord replacement
toro
https://www.youtube.com/watch?v=WQM1BnFx3hc
Briggs & Straton
https://www.youtube.com/watch?v=iczCZaRiR0Q
Aug 16, 2014 | Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
What is wrong with the toro push mower pull cord if it will not pull out?
I would say check the bolts that hold down the pull cord they are the same thread as the cover bolts but the cover bolts are a tad longer and if used on the pull cord housing they stick down to far and hit the fan blades on the magneto and it will not rotate
Mar 11, 2012 | Toro Lawn Mower With Toro Power Tools
Rover i4000 Q start
you will need to pull the top cover off the mower and follow the spark plug wire to the coil. when you pull the rope it turns a circlular drum that when it rotates near the coil will create a spark. you need to take some sand paper and clean the drum and the coil. there is probably some rust or film causing no spark.
hope this helps.
Feb 16, 2012 | Garden
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
How do I replace the pull cord on a craftsman 6.75 HP EZ walk?
Remove the three or four bolts holding on the pull cover and lift it off the mower.
Get a length of new pull cord and fish it into the hole the cord comes out of while passing it into the cord reel underneath the cover. There should be a hole in the reel where you can see where the cord should come out. Then you tie a knot into that end of the cord. With the cord now on the reel you wind it backwards with free end of the cable enough turns to **** in the free cord when you let it go. Usually 6-10 turns minimum. Remember to allow for the distance to the lawn mower handle! Unless your cord terminates at the top of the pull cover.
Good luck and be careful!
Oct 04, 2010 | Craftsman Garden
Pull cord is stuck
Take off your cover to the pull cord, the cord probably just got wrapped around the pulley. If you run into trouble with taking off this cover go to smalleng.com they will walk you through the process off pull cord removal and installation. Good Luck PAL.
Jun 11, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
May 04, 2010 | Mtd 22" Yard Machine Push Mower
Cannot find the sump plug on rover i4000 push mower
Jan 16, 2010 | Garden
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
