My tu2-etg adapter cannot connect - Computers & Internet
  • John Sparozich Apr 06, 2011
    Please explain what a tu2-etg adapter and what are you trying to connect to?
    Problem Solver:
  • 6 Answers
Go to the Device Manager by right-clicking on the Computer in the start menu. Click on 'Properties' and again on the 'Hardware' tab, and again on 'Device Manager' Expand the 'Network Adapters' category and right-click on your device. Choose either 'Update Driver' or 'Install Driver'. Choose 'Search Online'.
Posted on Apr 06, 2011
I need a driver for a trendnet tu2-et100. I'm running Windows 7 OS.
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
Aug 21, 2012 | Trendware TRENDnet TU2 ET100 network...
Trendnet tu2-400 not working
All hubs do is regenerate a signal out all ports at half duplex. I'd recommend getting a switch. Also hubs to computers technically need straight through cables to work correctly.
Jul 13, 2012 | Trendware TRENDnet TU2 400 (TU2-400)...
Teteteg etg
If you could provide more information on your problem I may be able to further help you. Otherwise if you don't mind spending a little money, this product claims to fix every problem that exists with the PS3. Hope this helps and best of luck! -Marcus Tuttle
PS3 Fixer
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
Have isolated problem to vhf/uhf connection point. white lines flash in pic. w/a popping sound & if they stay for very long there is a buzzing as in over white or over modulation. problem shows when...
Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
TV is approx 10 years old so I would recommend that do not spend lots of money on it.
Thanks.
Feb 27, 2011 | Sony KP-53HS30 53" Rear Projection...
Hello i am using a tu2-et100 with windows vista....and ever since ive started using it my computer has failed to fully load webpages, and videos online. On some websites my computer shuts down....leaving...
The issue is that the hardware driver for the USB is causing your system to crash. Try finding an update from Trendware- however your best bet is if you have a desktop, purchase a network card that goes internal, and if laptop- use an express card. USB network adapters historically have been *VERY* unstable- and the issues with your system definitely point at the driver for the adapter.
Oct 11, 2010 | Trendware TRENDnet TU2 ET100 network...
My home network was working fine for a long time. Here's the config: cable modem > main PC > Tu2-ET100 > xover cable > TU2-ET100 > second PC. I can connect PC to PC fine, Internet on main...
if one computer is working and the second one hooked on it not than it may be a cable thing ..if both are not working than it is a network and you have to call the provider...to check that plug them one by one directly to the main cable ..cause there is a possibility the the main ones LAN card to failed ..and cause both are basically connected trough it they can not work ..
Usually most computers have a on board LAN port ...if it is a suspicion that the LAN card failed try to use the one on board ..
Sep 02, 2010 | Trendware TRENDnet TU2 ET100 network...
Hardware problem
Connect the adapter on your computer then check the status of the device under the device manager. It should appear under Network adapters or USB Devices. double clikt its icon and look the device status. if you have the drivers installed successfully and you have tried it on different USB port, youmay try installing on another computer to further isolate the problem. If problem persist after installing it on another computer then it only means that there is something wrong with the device.
Jul 16, 2009 | Trendware TRENDnet TU2 ET100 network...
Main screen showing "no signal"
KP-43HT20 has 2 tuners, one is main (TU2) and 2nd is called sub tuner (TU1). Both tuners are mounted on A board located on right side of TV.
In my opinion, main tuner (TU2) is not working and causing No Signal message.
Let me know if you want to repair tv by yourself.to provide you more technical info.
Feb 21, 2009 | Sony KP-57HW40 57" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
