Question about Pioneer BDP-94HD Blu-Ray Player
Pioneer BDP-94HD says "no disc" when there is a
SOURCE: Pioneer BDP-f1FD Disc Tray Won't open
I fixed this on my unit from a tip on AVS Forum
Unit has "Power on" msg, follow these steps:
1) Hit power button for 5 -10 sec unitl unit shuts off
2) Press open / close button unit or remote first (do not hit power button first)
3) On the third try, the disc tray opened
I had James Bond Goldfinger in the player ( not sure if this had anything to do with it), I put another Blu Ray in and it loaded fine and is playing fine, hope this works for you
Dave
AVS link below
http://www.avsforum.com/avs-vb/showthread.php?t=1054927&page=413
Posted on Apr 26, 2009
rongxin
  • 57 Answers
SOURCE: Can't read star wars disks, all others work
maybe the copy of your star wars is not original disc.maybe is pirate dics.try buy new one star wars disk.rongxin
Posted on Mar 11, 2010
SOURCE: Trying to update firmware on
I had the same problem and immediately suspected that, as I had downloaded and expanded the .zip file on a Mac, I was suffering from the industry's usual bovine shortsightedness and that I needed to do it on a PC. I did and it worked. So I think the important part is to un-archive the .zip file on a PC, and find the file inside the resulting folder called
BDP12X_149.MVP
Make sure you have just that file on your USB stick, and no folders, and then the player should recognise it. You'll note that Pioneer's instructions don't mention this file name at all. Useless. Wish I'd bought another brand.
Posted on Dec 29, 2010
The reason it does this is because you are using a Mac's default un-zipping tool. Download Stuffit Expander and it will work no problem. - www.stuffit.com - It took me weeks to work this out. P O S.
Posted on Feb 27, 2011
Testimonial: "Good answer. Another solution (as i found out) was to download and unzip on a PC. Very backward of Pioneer to be un-Mac-friendly."
  • 100 Answers
SOURCE: I have a Pioneer DVD
Updated firmware and instructions are located on the manufacturers website:
http://www.pioneerelectronics.com/PUSA/Home/Blu-ray-Disc-and-DVD/Elite-Blu-ray-DiscPlayers/BDP-51FD?tab=firmware
I hope this helps
Posted on Mar 06, 2011
Pioneer bdp 440 won't play region A blu ray
It may be the encoder that is going faulty in the unit i had the same problem with my dvd player after using different regional discs in them.
Feb 21, 2013 | Pioneer BDP-440 Blu-ray 3D Code Free DVD...
"Hi Have a Problem With my Pioneer BDP LX91 Blu ray player,
Hi we had the same problem have you tried going into home menu/ initial setup/go down to playback/find BDMV/BDAV playback priority and make sure BDMV is highlighted and all should be OK.
Hope this helps if not could be a drive failure but try this first.
Oct 17, 2012 | Televison & Video
Need a firmware update for Pioneer elite BDP 05FD
The current firmware update for the Pioneer BDP-05FD is available from Pioneer: http://www.pioneerelectronics.com/PUSA/Home/Blu-ray-Disc-and-DVD/Elite-Blu-ray-Disc-Players/BDP-05FD . Click on the Firmware tab then download the .zip file (titled firmware upgrade). Extract the contents of the file.
Burn the .ISO file that is inside the .zip file to a new CD-R (or CD-RW) using your burning software. (If you have Win7, you can use the included burning software to do this. Just right-click on the iso in the file explorer and choose Burn Disc Image.)
Then check that the disc has the needed files and that the files are the correct size: DLfile.pkg 95.3Mbyte (99,942,480byte), .DLdiscidentifier.txt 93byte, DLdiscidentifier.txt 93byte (for v1.71)
Then put the upgrade disc into the player (work with the controls on the front of the player instead of the remote). Then wait until the disc ejects (do not power the unit off or unplug it). Remove the disc and then turn the unit back on. You should see various information show up on the screen that will indicate that the upgrade is in progress. If it doesn't give the prompts, then you may have an unreadable CD. Try burning a new disc at a different write speed (lower); try using a different burner/computer if problems persist.
I hope this helps.
Aug 05, 2011 | Pioneer Televison & Video
Won't play disc "cannot operate this disc" "cannot
I was able to fix this on my BDP-S350 by resetting to factory defaults and pulling the power cord on the system. It takes approximately 1 minute for the capacitor to completely drain the power. Once I replugged and powered up the system I was able to play a disc that minutes before had said "cannot operate this disc." Hope that helps.
Dec 25, 2010 | Sony BDP-S300 Blu-Ray Disc Player
My BDP-51FD can not read disc. At the time I bought I already feel it's very picky for the disc. And thing's getting worst later. And now it even showed no disc no matter what kind of disc I put in. I feel...
Try updating the software from Pioneer.com more than likely going to have to put the software update on a disk, burn it, and install it. The old Sony's work the same way but are hard. Good Luck
Dec 23, 2010 | Pioneer BDP-51FD Blu-Ray Player
Can't read star wars disks, all others work, this is the 2nd set that has failed. Pioneer BDP-120
Mar 11, 2010 | Pioneer BDP-120 Blu-Ray Player
Solution for "My sony sb 301 blu ray disk will not load It keeps
check with different Blu-ray discs and DVD discs. If the issue occurs only with some discs, then try updating the Firmware for the Blu-ray Player which should resolve the issue. Contact the Sony support team to get more information about the Firmware update for the Player.
May 09, 2009 | Sony BDP-S301 Player
Can not read disk
I just sent my BDP-S300 in with same problem...the tech told me he couldn't duplicate the problem and I think I know why...the fix is to UNPLUG the power cable and leave it unplugged for a minimum of 2-3 minutes...this process clears the internal memory; it seems that if you don't clear the memory, it won't read any disc because the unit thinks the same 'problem' disc is in the drive... (don't simply hold down the power button for 5 seconds - that will 'factory reset' the unit to default settings and you will have to reset your video / audio settings)...you have to physically unplug the unit from the power source...If I had waited a little longer before repowering the unit, I wouldn't have had to send the unit in (obviously the unit was without power during shipping and when it was powered up, internal memory was reset and thus did not indicate any problems). One more trick I learned is this - If a disc won't eject, turn the unit off, and instead of using the Power button to turn unit on, use the Open / Close button...the tech said the unit will then eject the disc before trying to read it...Hope this info helps!
Jun 20, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Pioneer BDP-94HD Blu-Ray Player Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
