Question about Daewoo DTQ-19V1FC 19" TV
Daewoo TV has no sound on just three chanels. The other chanels are fine. I tried the remote and also the TV volume...nothing ...The cable connection are good
jasonkoe
  • 64 Answers
SOURCE: ORION TV 1926A
lost the remote?... try a different universal remote. i have a orion 27" but i think it has a menu button on the front of the set. im at work.. when i get home ill check and repost....if you dont want to buy another universal.. barrow a friends and give it a try... sometimes the manufacture puts updated CODE's for the remote on the website.. might check that as well. good luck.. more to come.
Posted on Jan 22, 2008
  • 84 Answers
SOURCE: Daewoo DVN-14F6N
if your tv has a cable box, your connections should be as follows:
cable line from wall to cable box input. output from cable box to vcr
input. vcr output to tv input. both the tv & the vcr should be on channel 3
if you are using the rca cables,(red,white &yellow) just match the colors of the outputs
from the cable box out, to the vcr in, then vcr output to the tv. you will need to
put the vcr or tv on a aux channel or line/source input.if you don't have a cable box,
your vcr can be your tuner.scroll down on the tv channel down button till you
get to channel 3 or line in/source.if your vcr has all the channels programmed,
you can use the vcr remote to change channels.since you don't have tv remote.
most tv's if you scroll
down under channel 2 will give you the aux/line in/source inputs.
in some dollar stores they have universal remotes that may control
your tv.you can also try radio shack. let me know if this works.
the ledge
Posted on Sep 18, 2008
  • 89 Answers
SOURCE: toshiba that uses CT-90040 remote
if this is a time warner cable remote. the toshiba code is 015. sometimes a tv has several codes but only one controls everything. dont understand tuning video into tv. sounds like u need to plug rca wire into input plugs on the front or rear and then move switch to video but dont know what wires u r using.
Posted on Dec 27, 2008
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Posted on Apr 23, 2009
Raditronic
  • 196 Answers
SOURCE: TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Posted on Apr 21, 2010
How do i set the chanel to 3 so that i can hook up cable with out a remote
Most sets it is impossible and will skip channel 3 and input. You will need to buy a cheap universal remote.
Feb 27, 2015 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I am having problems getting my Daewoo TV to work with my dish network remote.
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to addressing your DISH remote to your Daewoo TV. We have a few different remote codes for each of our different models of remotes. The model number of your remote will be located on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes as well as the instructions for addressing the remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com.
Codes for Daewoo TVs
3.0, 3.1, 3.2, 3.4 IR remotes - 531, 719, 664, 727, 524 and 816
5.0, 5.2, 5.3, 5.4 IR remotes - 719, 531, 727, 526, 529, 530, 531, 684 and 658
4.0 and 4.4 IR/UHF remotes - 719, 727, 733, 531 and 524
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 531, 719, 727, 573, 652, 524 and 505
20.0 IR and 21.0 IR/UHF remotes - 531, 528, 832, 524 and 630
Instructions for addressing the remote to the TV.
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Sound quit while watching TV
Try to do fine tuning with all tv chanels
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
GE 46in Guide Plus Gemstar tv
I have sound from dvd player but no sound when I have just tv on
Nov 06, 2008 | Televison & Video
Daewoo DVN-14F6N
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
ORION TV 1926A
Jan 22, 2008 | Orion1934 19" TV
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Daewoo DTQ-19V1FC 19" TV Logo
54 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
