Question about Biostar MCP6PB M2+ w Athlon 64 X2 5000+ Bundle (MCP6PB M2+ w AD5000ODGIBOX) Barebone
Just installed new biostar mcp6pb m2+ mb with AMD Phenom X4 9750 also new. Goes thru POST and the displays "Miximum power of CPU is over 95w - shutting down in 5, 4, 3, 2, 1,", lights out! What's up?
    Genius:
  • 1,342 Answers
Did you do a custom setup in the CMOS/BIOS? Something in there is not correct.
Posted on May 14, 2014
2 Suggested Answers
rytechltduk
  • 72 Answers
SOURCE: I just installed a Biostar MCP6PB M2 motherboard
My first question would be have you re-installed windows or are you using the same hard drive and windows install? If you using the same install, windows does not like having the hardware changed so dramatically and would require a fresh install. Please let me know if this is a fresh install, with the error code from the blue screen if possible.
Posted on Oct 16, 2010
Testimonial: "Very Very Helpfull"
Need bios update for amd dual core 3.2 or phenom 9600
Hello here is the homepage:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#cpu
Only the cpu on the list, will fit the mainboard.
Others will be not be compatible with the mainboard, and a bios upgrade will not help with that.
Good luck
Feb 07, 2013 | Biostar N68S+ Motherboard w AMD Phenom X3...
BIOSTAR A960G+ AMD PHENOM II x4/ cpu max power 95W/ prepairing to shutdown with in 10 sec....what is the ******* problem in this unit? is it my processor? or my power supply or my new BIOSTAR A960G+ AMD...
Hi '' you have to specify what way your PC is shotting down'' do you mean that when you press power on of your PC and it do shot down just 10 seconds? so it means your PC does not boot , you cannot see letters or words while booting '' pls. keep in touch // thanks
Aug 23, 2012 | Biostar A960G Micro ATX AMD Motherboard
Anyone else having an overheating problem? my pc runs for a while, gets hot and just shuts off. if it's still hot it will shut down during boot sequence. any ideas on how to resolve? biostar mcp6pb...
Put a bigger processor cooler with plenty of thermal paste
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6101294&CatId=2545
and install a case fan.
Sep 16, 2011 | Biostar MCP6PB M2+ Motherboard
Where do i get a driver?
Go to www.biostar.com.tw/app/en/mb/driver.php?S_ID=387.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 03, 2011 | Biostar MCP6PB M2+ Motherboard w AMD...
Wanted biostar mcp6pbm2+ ver 6.3 audio drive free download
Here is the direct download link - http://www.downloadplex.com/Drivers/Sound-Multimedia/OTHERS/Download-biostar-mcp6pb-m2-ver.-6.36.46.56.7-motherboard_365057.html
Here is the download information page - http://www.downloadplex.com/Drivers/Sound-Multimedia/OTHERS/biostar-mcp6pb-m2-ver.-6.36.46.56.7-motherboard_365057.html
Jul 04, 2011 | Biostar MCP6PBM2+ nVIDIA GeForce 6150...
Biostar MCP6PB M2+
Hi.
You can download a manual from here
Make sure you have the 4pin connector for the cpu plugged in as well as the main power lead.
Disconnect any other wires you have put on.
Look for the block of pins (usually marked Panel) on the opposite corner to where the keyboard plugs in.
Pins 15 and 16 are for the power switch 15=+ and 16=Ground.
Best of luck.
Please rate this solution if it was of any help. Thanks
Feb 02, 2010 | Biostar MCP6P-B-M2+ & AMD Sempron LE-1250...
Processors fault
Here is the page that lists all CPU's for your MB:
MCP6P-M2 CPU Support
Thanks for using Fixya.
Apr 07, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
Biostar MCP6PB M2+ w Athlon 64 X2 5000+ Bundle (MCP6PB M2+ w AD5000ODGIBOX) Barebone Logo
124 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
