Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
I have an electrolux dishwasher model #=EIDW6105gS0. All lights are flashing on the console and will not let me select any of the modes...will not run at all. Is there any way to reset? I have tried cycling power to the unit and holding various keys....nothing works. Any help appreciated.
    President:
  • 1,140 Answers
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Apr 06, 2011
Is there a reset button on frigidaire dishwasher model fdb710lcb0
Mate im in Australia and don't know if the Frigidaite is the same as the Electrolux/Westinghouse but you can try this I posted a day ago:
On the Westinghouse and Electrolux dishwashers to reset a program that it defaults too you start the program and once initialised then press and hold the program button for about 3-5 secs. The panel will beep and all the lights will come on and not flash. From there on using the program button you select the wash cycle you want
May 28, 2016 | Frigidaire Dishwashers
My Electrolux Diswasher Model EIDW5705PS is stuck in Loc mode
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5705PS, keeps getting stuck in LOC mode. I also see that you are looking for another way to reset it, other than having to uninstall it. First, I suggest trying to unlock your appliance by pressing and holding down the "Air Dry" button for 3-5 seconds. If that doesn't work, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Electrolux EIDW5705PS 24" Stainless Steel...
How do i reset the consol?
already answered as solution to another question by you.
May 03, 2014 | Westinghouse Dishwashers
Electrolux dishwasher in locked mode
Good Afternoon David - When the light is on, the control is locked and no cycles can be selected or started. To de-select the Control Lock, press and hold the heat dry key or press down on the lock icon for approximately twenty seconds. If issue persists, you may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. The dishwasher should resume to normal operations.
Jun 24, 2013 | Electrolux Dishwashers
How to find leak in electrolux dw6105gs1a dishwasher
Check the door seals for any leak, and then the internal tub and underneath the unit by taking off the toe grille, or kick plate. If you cannot visually see any leaks, contact a professional service company - you might have a faulty sensor or a further control issue.
Dec 28, 2012 | Electrolux Frigidaire Professional Series...
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
Apr 21, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
1,302 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
