Question about Fuji Finepix S9600 Digital Camera
Got the darn thing soaking wet in the rain. bofy seems to work ok, but lens has fog. can take it off? how to getr rid of fog? thanks!
  • 116 Answers
Try to remove the lens and clean it from the inside lens because the fog is inside the camera's lens.
Posted on Apr 06, 2011
Peugeot 206 front fog light hal filled with water. how do i get rid of this?
You need a new fog light as you one is cracked some where you can remove the light by taking the inner wing off then remove the light by the torques bolt at the top
Aug 01, 2013 | Cars & Trucks
Padding under carpeting gets soaking wet after rain/wash
check your window seals and seals by defrost vent. One is leaking
Jun 19, 2012 | 2006 BMW Z4 Roadster
My head lights are very fogged i bought the restoration kit but cant figure out how to take off the cover to apply the soulution
Those restoration kits are only for the outside of the lenses. They oxidize and you use that kit to remove oxidation. If the haze is on the inside you need to replace the entire housing. They're sealed from the factory. Some people have tried to disassemble and clean insides but the success rate is very low.
Feb 18, 2011 | 2000 Mercury Cougar
2001 avalon--- Floor soaking wet after rain.
check the seal on your windshield most leaks sometimes start from windshield
Dec 21, 2009 | 2001 Toyota Avalon
My Panasonic Lumix DMC-TZ3 was soaked in water. It isn't working, will it work when it drys out?
It depends on how wet it was, if the entire thing was submerged, or even a large portion, it probably will not.it may turn on but it is likely that the lens will be damaged permanently. However if it was just wet upon the outside, like it was used out side during a rain fall, and then wiped dry every thing should be fine.It all depends,try drying it out thoroughly, letting it sit out with all lens caps and lens attachments removed, battery doorway open. is the best thing you can do. I hope that everything works out for you. God bless...
Aug 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
2001 Accord EX - Front passenger side carpet is soaking wet
The drain on the a/c evaporator gets clogged, you have to raise the car on a lift, or get under the car, on the right side of the car under the fire wall you will see a black rubber hose ( about a 1/2 inch in size) pointing down, you will need to blow compressed air in the hose to clear the blockage.
Apr 09, 2009 | 2001 Honda Accord
2001 Accord EX and the front passenger carpet is soaking wet
try draining the evaporator box.. u can have a shop lift the vehicle and blow compressed air up the evaporator drain tube from under the vehicle..the tube is under the car from the area of the passenger floor...it should pour out almost immediatelt after shooting compressed air up the tube ...stand back if doin it urself..or u will take a shower...sounds like u have a clogged evaporator drain
Apr 09, 2009 | 2003 Honda Accord
Fuji Finepix S9600 Digital Camera Logo
136 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
