Question about Alpine 16 Pin Original Head Unit Harness
I have a 97 toyota tocoma ext.cab. and am putting in my new cd player although my wires are not the same colors could you tell me what wires i need to match
    Sniper:
  • 50 Answers
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Posted on Apr 06, 2011
We have a 2000 Toyota tocoma 4X4 V6 3400 it had a fuel injector #4 out we replaced it and put new plugs, wires and put it back together and it still runs rough
-Test all injector's resistant to find the problem before replace it.
-Possibly fuel pressure or bad spark plug line.
Good luck
mai
Aug 05, 2015 | Toyota Cars & Trucks
Change starter in 97 toyota 4wd tocoma 3400 engine
Disconnect battery , undo starter motor wires undo two bo?t, s remove starter from motor,.
Nov 11, 2014 | Cars & Trucks
I have 97 for ranger with tape deck with cd player
This should help you wire up your new stereo. 97 Ranger stereo wiring diagram. They do make a plug in harness for your truck. Metra part number 70-5600.
May 10, 2010 | 1997 Ford Ranger SuperCab
Installing a a car stereo
Try crutchfiels web site.I put a sony in my 95 and just had to wire the GM adapter to the radio.They sent me everthing I needed including antena adapter and face plate adapter.Even if you didn't but the reciever ther just call them and they will tell you what you will need.
Dec 30, 2009 | 2004 GMC Sierra
97 toyota tocoma receiver dryer and lines
Unbolt the reciever dryer and the line remove and replace it and dont forget to use new Orings, Evacuate, check for leaks then recharge w dye type R134 freon. The dye will be in the system now so if it leaks anywhere you can easily find it with a UV detector light and glasses. Good luck.
Jun 23, 2009 | 1997 Toyota Tacoma
Engine replacement - distributor vs. coil pack - 97 Tacoma 2.7L
ok, try to put all accesories from your old engine to used engine, toyota dont make conversion kit, and the distribuitor is not compatible with your wires
Apr 13, 2009 | Toyota Tacoma Cars & Trucks
97 color scheme for aux hok up
I could go outside and pop my dash apart real quick and tell you.Its real easy to take it off and pull the cd player and radio right out.Is your wiring harness missing or something?Is that why you need to know what it looks like?
Nov 23, 2008 | 1997 Chevrolet K1500
#4 cyl misfires/code 304
P-0304 indicates number 4 cylinder misfire. Are you using Toyota parts dept spark plugs? More often than not, non-toyota plugs make the v-6s run poor, right out of the box....
Try this:With the engine running, pull the connector wire off of the #4 injector. Note to see if there is any change with the idle quality. No change? You may have a bad injector.
Aug 12, 2008 | 1997 Toyota Tacoma
JVC KD-G420 in 2000 Toyota Tocoma
today's in-dash cd players are a 2 part mounting system. One part is the carrier chassis that is hard mounted to the dash. Then the cd player slides into part 1 and latches. To remove player from part 1, insert 2 long and narrow metal tools along each side to un-latch the player. The tools come with a new unit. To make these, try making them out of 1/16 inch thick metal and trimming to following dimensions: 6 inches long by 1/2 inch wide and at one end, narrow down to about 1/8 inch about 1 inch from the end. deburr all edges. This 2 part system is designed for anti-theft defense.
Aug 26, 2007 | JVC KD-G420 CD Player
Alpine 16 Pin Original Head Unit Harness Logo
94 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
