Question about Digital Research Computers & Internet
My External Hard drive, when opened just flashes.
  • 116 Answers
It is already useless because the hard disk cannot be read but only the power
Posted on Apr 06, 2011
  • Digital Rese... Master
  • 27,725 Answers
Make sure the lead/s that attach to this drive have a secure seatings and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
From USB port unable to play the movies. The message unable to Protect, while opening movies from USB/ external Hard disk to play on TV Hisenese ER31607A
May be Speed of USB flash drive is equal or below Class 4.0. Try to check with Other higher speed USB Flash Drives. (Class 6 or Class 10 or HDMI)
Mar 21, 2015 | Hard Computers & Internet
Can't use
Just plug it in to your computers usb port make sure its connected properly
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive Click start all programs accessories open windows explorer navigate to your data
Right click on the data select copy navigate back to the External Drive.
or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
Once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device
if you need more help with this post a reply Hope this helps.
Dec 23, 2012 | SanDisk 16GB Ultra Backup USB 20 Flash...
Light flashing, HDD will not load, burning smell, not working please tell me my data has not been lost
being an external hard drive did the burning smell come from the connected computer or your external hard drive
open up the connected computer check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and possibly overheat
hope it helps
Apr 24, 2012 | Samsung G3 Station 1.5TB USB 2.0 External...
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
My external hard is asking to format everytime when i plugin
Files on a external hard drive can be corrupted if it isnot removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the external hard drive to working order you need to format the external hard drive,BUT you will lose the data stored on the flash drive.
May 03, 2011 | Computers & Internet
How do I put my downloaded movies into Lacie hard drive 160
if its on a flash or C drive....... go to my computer open the folder with the movie(s).....go back to start my computer open the external hard drive (where you are going to put the movie)..... now copy and paste or click and drag from (flash or C) to external......what ever software you are using to download the movie(s) you can also change the download location to the external (now you will download directly to external)
Jan 23, 2011 | LaCie (300728U) 250 GB Hard Drive
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I have an HP 1TB External Hard Drive, but it won't connect to my computer. A blue light continually flashes on the drive when the USB and power source are plugged in. I don't know how to fix this problem....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
All the best.
Jan 08, 2010 | Computers & Internet
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
External hard disk
the Hatachi 80 gig looks the same as the 120 gig verbatum 47558
also had the same blue flashing light and no recognition by XP
I open the case and removed the drive from the pc board. cleaned the contacts and reconected the PC board , the fault was oxidisation
May 30, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top Digital Research Computers & Internet Experts
David Payne
David Payne
Are you a Digital Research Computer and Internet Expert? Answer questions, earn points and help others
