Question about Kenmore 500 6952 Dryer
Dryer seems to overheat - Kenmore 500 6952 Dryer
  • 59 Answers
Check exhaust vent for clog. check thermostat attatched to coils for electric dryer, if gas check operating themostat or air shutters.
Posted on Apr 06, 2011
Dryer wont start
Is this a gas or electric dryer; helpful to know. The motor is not starting consistently? Focus should be on the motor and starting circuit. Possible bad connection, they need to be clean. Is there a starting relay? If a motor relay fails to disengage the start winding then the motor will overheat. Motor and motor circuit matches the symptoms described.
Jan 10, 2014 | Kenmore Dryers
Dryer will heat but seems to overheat and shut off.
If that is the style with the small heater in back up top the blower wheel is probably slipping.
Dec 27, 2013 | Amana Dryers
DV350AEP Samsung Dryer starts then stops after a few minutes
Sounds like you may need to take the whole dryer apart and check for lint build-up, or for a "worn-out "overheat thermostat switch" in the back or the bottom of the machine.
There are from 3 to 6 in most machines.
These parts, often the size of a quarter or half-dollar, usually have 2 wires hooked to them, and will shut off your dryer if it overheats (to prevent a fire).
These switches will require a testing instreument to check them.
Be blessed.
Mar 24, 2013 | Samsung 7.3 Cu. Ft Stackable Electric...
Dryer just started making squeeking noise and then seems to overheat and won't run again until it cools down.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfgshs
Sep 29, 2010 | Kenmore 63942 Dryer
Kenmore elite he3 takes wat to long to dry cloths
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Apr 21, 2010 | Kenmore Elite HE4 Electric Dryer
I'm not getting enough heat from my dryer
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before assuming there is a malfunction with the dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. Let me know if you require additional assistance.
Jan 05, 2010 | Dryers
The dryer heats, the drum turms, hot air circulates, but the clothes don't dry
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some advice on things to check before assuming you have a malfunction with the dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't exhaust properly, the moisture is retained in the dryer drum and your clothes stay wet, longer. A dryer in a clogged or poorply ventilated state can also cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know. I hope this helps you.
Dec 29, 2009 | Roper RES7646KQ Electric Dryer
Dryer takes too long to dry clothes...please advise
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
Dec 27, 2009 | Dryers
It takes 2 or 3 cycles to dry a load
The number one cause of dryer heat related problems is caused by poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
Dec 23, 2009 | LG DLE2516 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Kenmore 500 6952 Dryer Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
