Question about Uniden GPS
Um415 dsc marine radio,proper fuse size? - Uniden GPS
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
I have an older uniden marine radio that i just bought and i am wondering how i get on the weather channels
Turn the radio on, set the radio to USA then use the up-down channel selector and scroll down to channel 1 that's it. Good luck.
Jan 30, 2011 | Uniden Solara DSC VHF Marine Radio
Plug portable whip antenna into radio, power on with car lighter, no reception...how do I tell if radio itself is not working properly
To check your radio you will need a ANTENNA RADIO TESTER Shakespeare make a cheap tester STYLE: ART-3 works good. Good luck.
Jan 22, 2011 | Uniden Solara Vhf Dsc Fixed Mount Radio
Need a manual for uniden solara dsc marine vhf radio
http://www.uniden.com/products/productdetail.cfm?product=SOLARA%20DSC
Jun 03, 2010 | Uniden Solara DSC VHF Marine Radio
Which antennae to use with a Uniden Oceanus radio?
Marine two way radios operate on 156 MGZ. You have to use an antenna desinated for that purpose. Type marine vhf antenna on google search and it will pop-up lots of web sites.good luck
Jul 21, 2009 | Uniden Solara DSC VHF Marine Radio
I just purchased a uniden solara dsc.I HOOKED IT UP AND THE NOAA WORKS BUT I TRIED TALKING AND NOTHING HAPPENED.(I have a tractor with a radio and neither of us could hear each other).
The Uniden Solara is a MARINE RADIO not a CB. Marine (boat) radios operate in the VHF-Hi range and CB is in the VHF-Lo range. You also need a license to operate a marine radio, or you can identify yourself with the name of your boat but you MUST be in the water.
Jun 20, 2009 | Uniden OCEANUS-DSC-BK Base CB Radio
How to hook up an external speaker to uniden solara dsc vhf
the reddish-orange one and the brown one. The green and yellow ones are for data coming in.
Apr 08, 2009 | Uniden Solara Vhf Dsc Fixed Mount Radio
GPS Logo
Top Uniden GPS Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Martin Murray
Are you an Uniden GPS Expert? Answer questions, earn points and help others
